20 Most Recent EliteGroup P4VMM2 V8.1 Motherboard Questions & Answers
Motherbord wont boot or get any beeps
CPU is dead
3/26/2017 7:22:06 PM • EliteGroup... • Answered on Mar 26, 2017
What is compatible processor on P4VMM2
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&MenuID=24&LanID=0
5/25/2014 3:45:51 AM • EliteGroup... • Answered on May 25, 2014
0answers
0answers
Placa
Be the first to answer 6/28/2013 9:48:56 AM • EliteGroup... • Posted on Jun 28, 2013Be the first to answer
Manual to assembling motherboard
Hello the manual and drivers, can be downloaded here:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&MenuID=24&LanID=0Click on the link, for downloadAdobe reader is needed, to read content.Good luck
1/28/2013 2:32:29 PM • EliteGroup... • Answered on Jan 28, 2013
Maxtor one touch
Hello i think you need the usb driver from here:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&MenuID=24&LanID=0If any other drivers missing install them.Look in the device manager for drivers problems.Seagate has the support for your product:http://www.seagate.com/support/external-hard-drives/desktop-hard-drives/onetouch/You maybe need some software for the drive:https://apps1.seagate.com/downloads/request.htmlEnter the model or serial number to find any software.Good luck
12/30/2012 7:24:08 PM • EliteGroup... • Answered on Dec 30, 2012
Free driver download
Free download of drivers can be obtain through the product website. Just visit the motherboard official website. Click here to be redirected to there download page.
Thank you.
12/1/2012 4:42:30 AM • EliteGroup... • Answered on Dec 01, 2012
NOTHING APPEARS ON SCREEN
Is their any beep if you heard one single long beep then it is a problem with memory or if you hear two short one long then problem is with your display card, And if POST screen is visible then problem is with your Computers OS
8/24/2012 3:37:51 PM • EliteGroup... • Answered on Aug 24, 2012
Audio driver
http://www.motherboard.cz/mb/ecs/P4VMM2V81.htmAudio driver should be in the bundle
7/7/2012 6:06:06 PM • EliteGroup... • Answered on Jul 07, 2012
No driver
the drivers might be installed properly for this device click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one http://download.cnet.com/intelv13-zip/3000-2112_4-195759.html http://download.cnet.com/intel-pro-network-zip/3000-2112_4-165499.html http://download.cnet.com/intel82573l-zip/3000-2112_4-165111.html http://download.cnet.com/cnr4032500-zip/3000-2112_4-161519.html if these driver packages aren
9/21/2011 8:14:23 AM • EliteGroup... • Answered on Sep 21, 2011
Usb problems
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question exclamation mark? ! or a red X you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
8/20/2011 6:44:31 AM • EliteGroup... • Answered on Aug 20, 2011
Re; HP 6735b Laptop Bios and
Hi george.I'm afraid you will have to get in touch with HP about this problem. The reason being is that yes you can de-solder the BIOS chip but this is very hard to do with it being on a laptop motherboard. You will need a very steady hand and also a heat gun to melt all the solder points on the chip to remove it, then you have to get the new chip in place properly which again is not easy, even for a tech like me!! To be honest with you I personally wouldn't bother trying to do this because it's that hard to do. If you can prove ownership of the laptop then HP will give you the master reset code to wipe the password from the BIOS.I'm sorry but this is the best advice I can give you.Kind regards.
8/12/2011 5:23:45 PM • EliteGroup... • Answered on Aug 12, 2011
After formatting my usb port
that means you have deleted the driver for the sub.please get another driver for it before it can recognize it. thanks
8/5/2011 3:19:59 PM • EliteGroup... • Answered on Aug 05, 2011
2answers
1st question== my friend gave
that's a functional motherboard you got there. The beep that you hear is an error beep for not reading a ram. Yes, you will insert a ram that is compatible with your motherboard. No you can't use that without a video card. If you've got a spare video card put it on your motherboard
8/2/2011 2:06:43 AM • EliteGroup... • Answered on Aug 02, 2011
I need the driver of
P4VMM2 V8.1
The link above will provide what you're looking for.
Kindly give feedback if I helped you. Thank you for posting.
7/3/2011 11:53:19 AM • EliteGroup... • Answered on Jul 03, 2011
2answers
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT º 1 x AGP 4X slot
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&CategoryID=1&MenuID=18&LanID=19
i hope this helpful
thank you for using fixya
2/6/2011 2:06:22 PM • EliteGroup... • Answered on Feb 06, 2011
Motherboard driver download
hi.
a motherboard driver is created by many drivers.
however you can use the following link and download "Chipset driver":
http://www.driverstock.com/EliteGroup-P4VMM2-driver-download/25-9-3830/index.html
1/29/2011 6:57:15 AM • EliteGroup... • Answered on Jan 29, 2011
2answers
My p4vmm2 rev.8.1 has only
Looks like the max is 2 x 184-pin DDR DIMM socket support up to 1 GB, which means you can get 2 512MB DDR266/200 2.5V DDR SDRAM chips.
as far as video cards, it will accept any AGP 4x or lower card. You could also put a PCI video card in it, but AGP is better.
12/28/2010 12:58:35 AM • EliteGroup... • Answered on Dec 28, 2010
2answers
Where can i find free download of my lost mother
Hi there!
To be quick, here is is:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=359#Download-1
Hope it helps,
levibit
12/8/2010 3:11:30 AM • EliteGroup... • Answered on Dec 08, 2010
EliteGroup P4VMM2 V8.1 Motherboard Logo
Popular Tags
58 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
nothing appears screen
  • Computers & Internet
