20 Most Recent EliteGroup KM400-M2 Motherboard Questions & Answers
5answers
I am upgrading to windows
minimum 2GB for smooth use of the pc, but RAM is fairly cheep so I would go for 4GB. The most importet hardware to be fast is your harddrive.
6/17/2023 6:21:25 AM • EliteGroup... • Answered on Jun 17, 2023
Push on button and CPU fan makes 3 turns then all
As dassault1 just said. i have never heard of a anti bounce mode. but try this link might help you out... CPU fan makes 3 turns then all stops Google Search
10/25/2017 10:15:45 PM • EliteGroup... • Answered on Oct 25, 2017
2answers
Km400-m2 driver
Go to the product site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=511&DetailName=Feature&MenuID=24&LanID=9
you will get all details of your motherboard including manual,driver etc..
Click on Download you will get all drivers .
Thanks for using FixYa.
5/16/2011 3:12:55 PM • EliteGroup... • Answered on May 16, 2011
4answers
I wish to upgrade my
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
5/6/2011 1:26:06 AM • EliteGroup... • Answered on May 06, 2011
Hello, Although I changed the CMOS battery and
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
4/29/2011 8:47:29 AM • EliteGroup... • Answered on Apr 29, 2011
2answers
Hello, when I put my pc
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
4/28/2011 11:30:41 AM • EliteGroup... • Answered on Apr 28, 2011
I have a KM 400
you need an ide sata converter attached to your hard drive
hope this helps
9/13/2010 3:20:52 AM • EliteGroup... • Answered on Sep 13, 2010
Receiving no video signal at monitor.
use AGP ver2 cards plz
6/23/2010 8:18:12 PM • EliteGroup... • Answered on Jun 23, 2010
Why my motherboard ecs KM400-M2 will restart if i
Try to install 2GB single RAM on the board because some time its not support 2, 1 GB RAM with different manufacturer.
Regards
Ashly
2/2/2010 10:15:36 AM • EliteGroup... • Answered on Feb 02, 2010
No video to check/change bios and beeping every 2
Hi, having no display when switching on the computer may occur for several reasons but the main reasons are often a bad seated or faulty ram or a damaged vga card that you may also try to re seat and clean before replacing .
I hope that it will help you & don't forget to rate post
Kind regards
1/19/2010 4:07:16 PM • EliteGroup... • Answered on Jan 19, 2010
I have problem whith Video Drivers can you help
update drivers from microsoft
1/8/2010 12:51:32 PM • EliteGroup... • Answered on Jan 08, 2010
A short beep every second coming through the
Hi royjack74,
a repeated beep is a memory issue. First check for improperly seated or missing memory.
Good Luck
Mark
12/13/2009 12:32:07 AM • EliteGroup... • Answered on Dec 13, 2009
Is it possible to run vista aero on EliteGroup km400-m2?
Vista Aero is dependent on your Graphics hardware, not on your motherboard. The onboard VIA/S3G is not going to be capable of running Aero, but you do have an AGP 8x port that you could buy a card for. Try picking up an ATI 48xx series card if you plan on doing some gaming. If you just want to run Aero, however, just about any card nVidia 76xx series, 86xx, 96xx, or any ATI 26xx, 36xx, or 46xx series card will do.
10/19/2009 8:32:06 PM • EliteGroup... • Answered on Oct 19, 2009
Hi, im installing my operating system but the pc
Dear,
First you have to see the CDROM wthere its reading correct or not? before that you have to change once RAM and try again. It will work. okey. Due to frequency mismatch it will occur.
Cheers
Jaggu
9/28/2009 10:45:50 AM • EliteGroup... • Answered on Sep 28, 2009
Short burst of power
Most likely you have a bad power supply, or a short or overload that causes the power supply to shut down. You will need a DVM (digital volt-ohm-meter). Using the DVM and the instructions on the PS, unplug all PCI boards and all wires on the HD's. There should be a point where the PS will not shut down. Then you will have to install all the connections one by one, until the PS shuts down. You will have to turn off the computer for each of the connects and each of the re-connects or you are exposing your computer to a great danger. CONSTANTIN (arzconst)
7/31/2009 10:09:58 PM • EliteGroup... • Answered on Jul 31, 2009
KM400-M2 V1.0 - main board
Power off the system & unplug the power cored. Pull your memory. Than re-seat it. Make sure the memory is fully seated. See bios beep codes for the Award bios. Click this link;
http://www.bioscentral.com/beepcodes/awardbeep.htm
4/4/2009 5:20:11 PM • EliteGroup... • Answered on Apr 04, 2009
2answers
Bios password problem
If you forgot the biosw password, you need to access to the motherboard, and remove the battery for five seconds.
This will reset the bios password.
12/1/2008 11:48:47 AM • EliteGroup... • Answered on Dec 01, 2008
Motherboard asus km400/km266
there is a jumper on the board marked
pswd
or
clr bios
it is a 3 pin jumper and 2 are jumped now , move it over.
3/15/2008 5:01:54 AM • EliteGroup... • Answered on Mar 15, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
EliteGroup KM400-M2 Motherboard Logo
Popular Tags
30 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
push button cpu fan makes 3 turns all
  • Computers & Internet
