20 Most Recent
EliteGroup nForce3-A Motherboard Questions & Answers
I dont now how to connect my motherboard
You should have got a guide book with your motherboard. Refer to that. Also you should be specific to what your having problem in connecting.
Also, you would be able to find better support if you contact your vendor :)
I cant install my ethernet driver..
If you use a hardwired eathernet connection though that port you are installing the driver for, then no, you will not be able to access anything outside of your computer.
I LOST MY MANUAL AND I CANT HOOK UP MY NEW CASE
Hello.
You can download (and print) the Manual at this site:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=502&DetailName=Feature&MenuID=52&LanID=0
Just click manual, then click USA under the English Manual.
NOTE: You must have Javascript installed on your Internet Browser, and Adobe Acrobat Reader to read PDF files.
Case cables connectors are usually located on the bottom right of the motherboard. (HD LED, PWR LED, PWR SWT, RES SWT, USB, and AC 97').
Hope that Helps.
Blue screen when trying to boot windows
you have the "blue screen of death" i had this same problem and the easiest way to fix it is to take the hard drive out and put it into another computer back up all files you want to keep on it have a boot disk for the right windows operating system on it use the boot disk with it once it is back in the right computer and then put all the files you saved back on it. the blue screen of death occurs when there is a registry error on your computer. if the blue screen of death appears again then you need a new computer.
How to jumpe SDRAM to DDRAM
according to my research- this mobo will support 2GB ddr400/333 sdram- 1GB in each slot. don't think it will support ddram. don't know if you can mix 400 and 333 bus speeds. probably can, but put 400 in slot 1. not sure ddram will even fit in ram slots!
good luck!
Where are the sata drives???
Plug the drive in, restart your machine, as it starts up enter the BIOS and set the bios to defaults, hit F10 save the changes and exit the BIOS.
The computer will restart and the SATA drive should now be recognized by the system.
Good luck
NFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
Lan problem
Dear user,,
pl log on to
http://www.driverguide.com and creat your account and go to the driver tab and found driver by *********** board make and model no.
Regards,
Ravindra shah
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
