20 Most Recent
Technics SL-MC700 110-Disc CD Changer Questions & Answers
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
5/23/2015 6:50:00 PM •
Technics...
Answered
on May 23, 2015
Replacement parts
Take the broken belt to ace hardware and find an o-ring that is the same size.
1/29/2015 10:58:35 PM •
Technics...
Answered
on Jan 29, 2015
C F - 15 Error Code
did you ever find out what this was ? mine now reads the same and won't load discs.
11/21/2013 1:27:25 PM •
Technics...
Answered
on Nov 21, 2013
Error code F-26
The servo LSI has malfunctioned.. but I don't know what that means, and where I can get it fixed.... do you??
8/15/2010 2:50:46 PM •
Technics...
Answered
on Aug 15, 2010
Front door won't open
open the player wit the door ejected then clean all dust particles
inside it especially below the door and on the way where the door
closes ... and then also clean the rubber belt & near by which is
connected to dc motor... and clean the lens also... remember clean
only wit dry clothes...
bye cleaning lens it will solve ur playing problems slightly..
and by cleaning near by & bottom of door and door way solves ur half way ejection problem
2/6/2008 8:35:18 AM •
Technics...
Answered
on Feb 06, 2008
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
2/6/2008 8:32:43 AM •
Technics...
Answered
on Feb 06, 2008
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
1/15/2008 3:09:36 AM •
Technics...
Answered
on Jan 15, 2008
Home theater system
Check all your speaker connections firstly as you may have a short on speakers.try disconnecting speakers at amp side one at a time to see if overload dissappears.If this doesnt help you have an output problem internally and will need to see the doctor
5/17/2007 8:19:40 PM •
Technics...
Answered
on May 17, 2007
Technics RS-BX501 cassette deck door won't open
If you feel confident doing so, you could attempt to open the cassette deck and physically examine the gears to check for damage or debris that might be obstructing them.
But do remember that there are risks involved when opening electronic equipment, especially if you're not used with doing this kind of work. If you're not sure you can do this securely, it would be preferable to get assistance from a qualified audio equipment repair specialist.
