20 Most Recent
Adobe Systems Adobe Reader Questions & Answers
Pdf file cannot open
What version of Reader are you using? Some newer .pdf files ure using formatting codes that older versions of Reader cannot decipher and thus fail to open. Older files will still read regardless of the version of reader. Ensure you have the most recent version of Reader and try again.
PDF password cracker and remover
Now easily use the best PDF Password Remover software that easily works for removing the protection from PDF file and also unlock excel file protection. By taking help of this wonderful PDF password Unlocker Software users can unlock protection from PDF file and software supports all windows versions included latest one windows 10. It provides demo version facility under which users can freely get password with watermark.
http://www.osttopstapp.com/pdf-unlocker.html
PDF file cannot be opened
Try another PDF file program, such as Foxit Reader, to see it it can open. If the same error occurs, the file is probably no good.
Adobe Reader X 10.0.0
Check the network path. PDF files do not open only from network folders with DFS paths.
\\mynetwork\doc\manual.pdf
And everything perfectly works if in way to specify the server:
\\myserver\doc\manual.pdf
This problem is in protected mode of the program. That Adobe Reader X didn't give out more mistakes, this mode needs to be turned off.
1. Start Adobe Reader X
2. Go into Edit - Installations ...
3. In category choose the Basic
4. Take off the checkbox "Enable protected mode at startup"
5. Restart Adobe Reader X
Everything should work.
If the file does not open, then it means it is damaged. You will be able to recover it by using Recovery Toolbox for PDF
https://pdf.recoverytoolbox.com/
Look at this forum. There are tips on this topic. Maybe you will be helpful. Good luck!
http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/1913-how-to-open-corrupted-when-downloading-a-pdf-file
Cannot read document
you should first download and then open that. what is your browser? what is your acrobat reader software?
