20 Most Recent Microsoft Office Access 2003 (077-02871) for PC Questions & Answers
2answers
What is the extension file name for a microsoft
According to Wikipedia:-
Access Project .adp
Access Blank Project Template .adn
Access Database (2007) .accdb
Access Database Runtime (2007) .accdr
Access Database Template (2007) .accdt
Access Database (2003 and earlier) .mdb
Access Database, used for addins (2,95,97), previously used for workgroups (2). .mda
Access Database Template (2003 and earlier) .mdt
Access Workgroup, database for user-level security. .mdw
Access (SQL Server) detached database (2000) .mdf
Protected Access Database, with compiled VBA (2003 and earlier) .mde
Protected Access Database, with compiled VBA (2007) .accde
Windows Shortcut: Access Macro .mam
Windows Shortcut: Access Query .maq
Windows Shortcut: Access Report .mar
Windows Shortcut: Access Table .mat
Windows Shortcut: Access Form .maf
6/12/2023 6:43:54 PM • Microsoft Office... • Answered on Jun 12, 2023
5answers
Eager To Learning MS Access
The easiest and fastest way to learn the basics of any of the main office programs is with multimedia tutorials. Ranging 5-10 times faster than text. More can be learned in this way in a shorter time.
In regards to VBA, if you only want to work with macros and scripts within an application, a minimal knowlege is all that is necessary. If you are wanting to use VBA across applications, you will need a little more depth of knowlege (at least in my case) is needed. May I suggest Microsoft's 'inside out' series of books. It looks intimidating but you only need the section you are studying.
There is something special about getting tutorials and learning information from the actual program manufacturer. They are the authority and free.
Okay, my suggestion is to first go to Microsofts website and view the tutorials available for your application: MS Office tutorials
Then, if you find your thirst for knowledge unquenched:
  • Third party online tutorials are often quite good. But often the depth knowledge like VBA will turn into a 'tips and tricks' rather than the foundation needed.
  • Get some of the multimedia learning, all it takes is a few 20 minute segments. Titles like Mastering Access 2003 by Magic Media, includes VBA.
Learning some of these applications can be very daunting. It is estimated that your typical user will use only around 10% of the programs capabilities. And they keep adding capabilities! Anyway start easy and work your way up to the complexity you want.
For the other users that have similiar problems, the real answer is to learn the above. But to convert numbers to words you need to redefine the field as text, and enter numbers.
And if you are setting up a search criteria for multiple text boxes using IF condition, it depends on what you are comparing. If you are comparing to a set quantity it would look something like this: IF field/text box = "Fixya" THEN performed action. Endif. If you are comparing two or more text boxes to each other it may look something like this: IF field/textboxA = fieldtextboxB or fieldtextboxC THEN action Else action. Endif
Hope this helps!
Ted
3/19/2018 12:19:32 PM • Microsoft Office... • Answered on Mar 19, 2018
3answers
....where to download ms access
Ms. Access is part of Microsoft Office and you cannot download for free.
But you can download Ms Access database viewer from here
2/2/2018 9:58:53 AM • Microsoft Office... • Answered on Feb 02, 2018
2answers
Access problem
see if the LDB file still exist and delete it...
Whenever you open an Access database, a file with the same name as the database and an extension of LDB will be opened automatically. For example if you open Northwind.mdb in the samples directory of your Access/Office installation, a file called Northwind.ldb will be generated. This new file keeps track of users and the objects that require some form of locking in the database. When all users have exited gracefully from the database, the LDB file is closed down and deleted.
thanks for rating
10/12/2017 10:08:21 AM • Microsoft Office... • Answered on Oct 12, 2017
2answers
You are offering microsoft office 2007 free ......
NO
You PAY for MS Office, try http://www.openoffice.org/
FREE word processing program.
10/21/2016 6:03:18 AM • Microsoft Office... • Answered on Oct 21, 2016
Cannot open database ext.accdb
accdb extentions must be opened with 2007 or later. 2007 and up will open ext.mdb. 2007-2010 will convert an mdb to accdb. 2013 will not convert but will open them.
2/23/2015 2:33:29 AM • Microsoft Office... • Answered on Feb 23, 2015
MS access - how to insert a function in a access table
Have you reached resolution yet? If not I would be happy to help otherwise, I would be interested to know what happened. It sounds like you need to call the date (today) for the appropriate balance to come in automatically - assuming you have a table holding this data. Thanks for rating FixYa!
2/23/2015 2:29:50 AM • Microsoft Office... • Answered on Feb 23, 2015
I want to reject someone from phone caslls and
install an antivirus app. most have privacy setting that can block a particular number.only for android.
10/17/2013 7:31:22 AM • Microsoft Office... • Answered on Oct 17, 2013
2answers
Access Database opening in read only
check the folder type it may be just set for read only. the administrator has the option on the interface to see if the database is read only for others or if it is editable.
1/10/2013 8:40:26 AM • Microsoft Office... • Answered on Jan 10, 2013
Update a record and save it in two or more tables.
First, make sure that the tables that you are using have some sort of Primary Key so that the correct records can be linked.Next, choose 'Tools' -> 'Relationships' from the top menu.Add the tables for which you want to link together. Drag the correct field from one table to the next table. A popup window should appear.In the window that appears, choose the 'Enforce Referential Integrity' and 'Cascade Update Related Records' options.Now, whenever you change the field in one of those tables, the corresponding filed in the other table should change as well.
12/12/2012 4:21:14 PM • Microsoft Office... • Answered on Dec 12, 2012
2answers
Microsoft Access 2003
its hard to fully explain but you can download this file as an example to how you can solve the problem via running a simple query from which you can copy the new phone numbers for the new phone column and paste it on the old phone column . its just that easy .
go to http://drop.io/dalhelo
download the file ]sample.mdb[
all the best
6/7/2012 3:19:38 AM • Microsoft Office... • Answered on Jun 07, 2012
2answers
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
11/30/2011 6:59:33 AM • Microsoft Office... • Answered on Nov 30, 2011
Information in access database is visible if print
I don't really understand your problem. Is it a table you cannot see? or a Query? You may not be able to see some things unless you have a default printer set up on your computer. Access is weird about that. Please get back to me with more specifics. Thanks!
3/16/2011 6:53:03 PM • Microsoft Office... • Answered on Mar 16, 2011
I am problem becouse is nor program access
make sure microsoft is compatble to your system 64+32bit.
2/11/2011 10:46:31 AM • Microsoft Office... • Answered on Feb 11, 2011
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
1/8/2011 2:58:28 PM • Microsoft Office... • Answered on Jan 08, 2011
My brother give a cd with some mc office 2003 for
Microsoft Office Access 2003 product key
11/12/2010 11:09:35 AM • Microsoft Office... • Answered on Nov 12, 2010
How to download microsoft office
If you mean free, you can download it from torrent sites like btjunkie and isohunt. You will need a torrent client like utorrent
10/2/2010 9:23:04 PM • Microsoft Office... • Answered on Oct 02, 2010
Using Microsoft Access I'm creating a database to
The easiest way to achieve your goal, would be to use a second interfacing application to hand the database operations. I suggest VisualBasic.
9/7/2010 3:00:27 PM • Microsoft Office... • Answered on Sep 07, 2010
Microsoft Office Access 2003 (077-02871) for PC Logo
85 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Office Microsoft
  • Office Microsoft
Most Popular Question
  • Computers & Internet
