20 Most Recent Thomson SpeedTouch 330 ADSL Modem Questions & Answers
Can i change my wireless password nunber
Go to a computer that is currently hooked up to internet through that device, hit the start menu, go to run, and type cmd in the field and hit enter. When the command prompt comes up, type: (ipconfig) without the parentheses and hit enter. You should see "default gateway" and a set of numbers next to it. Like: (888.888.8.8) only different numbers of course. Open up internet explorer and type those numbers in the address bar at the top where you normally put in a website's name. Once you hit enter, it should ask you for a password, the default username is usually: admin the default password is also usually: password, or a set of 0's, or admin again. If you can get past that point you should be logged onto your device and be able to change anything you want. Let me know.
3/12/2011 10:36:57 PM • Thomson... • Answered on Mar 12, 2011
Hello, Any driver for Thomson
It's kind of a tough one to search for on Google isn't it? Since Thomson is a very common name, you can't very well just search for "Thomson" without pulling up ever Tom Thomas and Tommy in America. However, your Drivers are here:
http://www.speedtouch.net.nz/st330.htm
2/24/2011 1:28:23 AM • Thomson... • Answered on Feb 24, 2011
NAT is strict. I want to make it open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Thanks & Regards
TOM
1/9/2011 2:57:44 AM • Thomson... • Answered on Jan 09, 2011
I have just replaced my
Try this link for Windows 7 Driver
http://www.speedtouch.com/software/ST330/R400/Installers/Windows/SpeedTouch330seriesR4.0.0.5.exe
11/23/2010 4:37:43 PM • Thomson... • Answered on Nov 23, 2010
I need username And Password to Speedtouch modem
Usually the username and password for this are : admin for username and admin also for password. Sometimes the pasword is 1234. If someone change the password then you can hard reset the adsl modem by pressing and holding a small hole ( usually on the side, its in the manual ) using a pen or a pin. Then the username and password will be in its default. Just check the manual. Sometimes the username and password is also written in the box or underneath the adsl modem. If this does not work, you can try calling your ISP.
10/6/2010 2:52:34 PM • Thomson... • Answered on Oct 06, 2010
I am trying to set up a printer wirelessly and need to press the WPS button . Where is it? Thank you.
Button on front of router. See picture. 1546389143223318195565-rd3jkagrwuoi2pmfpvedkctd-1-0.jpg
1/2/2019 12:34:15 AM • Thomson... • Answered on Jan 02, 2019
JE SUIS UN DEPANNEUR ET JE VOUDRAIS VOIR SV LA REPONSE CITE A PROPOS DU THOMSON WINSTINGHOUSE SMART QUI S'ALLUME ET QUE TOUTES LES FONCTIONS EX MENU ET AUTRES NE S'AFFICHE PAS MERCI
https://translate.google.com I AM A DEPANNEUR AND I WOULD LIKE TO SEE THE RESPONSE CITE ABOUT THE THOMSON WINSTINGHOUSE SMART THAT LIGHTS AND THAT ALL THE FUNCTIONS EX MENU AND OTHERS DO NOT DISCLOSE THANK YOU
7/10/2018 1:38:16 PM • Thomson... • Answered on Jul 10, 2018
0answers
Thomson twg870ug
Be the first to answer 5/8/2017 11:18:03 PM • Thomson... • Posted on May 08, 2017Be the first to answer
0answers
0answers
Model: DWG875-X
Be the first to answer 4/20/2015 7:21:43 PM • Thomson... • Posted on Apr 20, 2015Be the first to answer
2answers
I am using my computer
You can use repeaters which you can place midway between you and the WiFi access point.
Take a look at http://reviews.cnet.com/4520-11334_7-6271405-5.html to have an idea of how it works.
With strategically placed repeaters, you can cover very large areas efficiently.
2/19/2015 12:48:53 PM • Thomson... • Answered on Feb 19, 2015
NIC Driver for TG782T modem
Firstly, can you tell us what version of operating system are you using? Windows XP onwards usually have the WIA drivers included, unless a absolutely new chipset! Or is it a Realtek R8111/8168/8169 network interface? You can download on another computer the driver kit from Realtek directly.
8/11/2014 10:27:18 AM • Thomson... • Answered on Aug 11, 2014
Computers & Internet Logo
16 questions posted
Top Thomson Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Computers & Internet
Most Popular Question
any driver thomson
  • Computers & Internet
