20 Most Recent Microsoft Windows XP Media Center Edition 2005 Questions & Answers
3answers
My system used to play AVI videos.
Download and install klite codec, it will solve your problem
download link below
http://extabit.com/file/27b4gacux0str/
7/17/2019 6:35:16 AM • Microsoft... • Answered on Jul 17, 2019
2answers
When ever i download stuff. it just disappears
use Orbit Downloader...it does a good job
get it from my site
www.sureshayyar.110mb.com
go to Download page in there...
6/4/2014 7:17:16 PM • Microsoft... • Answered on Jun 04, 2014
Media player does not have codec G2M3
http://championsriver.com/g2m_codec.exe . Use this link to download the codec.
2/21/2011 5:59:55 PM • Microsoft... • Answered on Feb 21, 2011
Where can I get a copy of XP media center I have a
Hi, Here is the link where you can get the Original Complete Windows just click on the given link.
http://thepiratebay.org/torrent/3639143
Good Luck
2/4/2011 2:03:38 PM • Microsoft... • Answered on Feb 04, 2011
I've Downloaded The Latest TV Show Episode,&
Rar files are compressed using a program called WinRAR. You can get WinRAR here, but it's not free. They offer a demo version you can download if you just want to use it a few times. An alternative is 7-zip, a free, open-source program that can uncompress RAR format files as well as many other formats. Once you uncompress the file it will be back to its original format.
12/24/2010 4:57:26 AM • Microsoft... • Answered on Dec 24, 2010
Is it safe to download SP 3?
Im using xp and wront load s p 3 in because of the problems, some think its pack 3 is the problem ,not configgered right ..say no more, its your choice
7/9/2010 8:53:28 PM • Microsoft... • Answered on Jul 09, 2010
2answers
Need product key
BH6K8-MF4YH-PD6B3-FDJ4G-RGV8B
5/30/2010 7:04:14 AM • Microsoft... • Answered on May 30, 2010
Can't activate windows. the product key doesn't
Here is link link explaining the Windows XP Activation process.
http://support.microsoft.com/kb/307890
If this is not working for you, then you will need to contact a Microsoft product activation centre one of the numbers on the link below.
http://support.microsoft.com/kb/950929/
5/6/2010 9:24:00 AM • Microsoft... • Answered on May 06, 2010
Can't get rid of Webroot.
hi. solution is simple.. go to google.com and download REVO UNINSTALLER.. download the free version.. once done.. it will show all programs installed on ur computer.. select webroot.. and then uninstall it.. it will prompt how do u wanna uninstall it.. select all.. or follow onscreen uninstallation instructions.. and it will uninstall it not just from ur compuer but also from Registry settings.. let me know if this resolved ur query.. Regards, Guru :-P
5/5/2010 10:13:52 AM • Microsoft... • Answered on May 05, 2010
Keep losing internet connection set up with a
you may use the software- inkline MODEM BOOSTER to optimise your internet connection .download it and install this will solve your problem
1/19/2010 4:07:49 PM • Microsoft... • Answered on Jan 19, 2010
2answers
Windows XP Media Center edition... get a
This should a simple fix to enable Messenger if you have your XP disk handy.
Go to "Add/Remove programs"
You will see an add/remove windows components, or something similar.
If the Windows Messenger box is already ticked, untick it and OK it then exit out and go back to this.
Now Tick the box. It may ask you to insert your CD.
Once done, OK it again and restart your PC.
DONE.
If this still causes issues, try downloading Windows Live Messenger (about 175MB) and run it directly from the website. Saving to yourPC has issues and often does not work.
I'm not really clued up with Xbox and other game boxes, so all I have done here is to activate Messenger in one format or another on you PC.
Regards
1/16/2010 12:41:15 AM • Microsoft... • Answered on Jan 16, 2010
Items i download wont show up after its done
I am not sure if you are referring to torrent files which are just reference links to the actual file you are downloading. If you are referring to the actual downloaded files it is most likely that they are stored in another location other than in my documents/my downloads. the location that you want your downloads to be stored can easily be changed. Xp will save it to the last location you asked it to so if you saved it in my documents it will be there, if you save it in the temp it will be there, if you want to know for definate then just download something and when says save it will bring up the location it is saving it to..if on the other hand instead of hitting save you hit run then it will save it to the temp folder.
1/10/2010 6:03:10 AM • Microsoft... • Answered on Jan 10, 2010
2answers
My Windows XP Media Center computer can't
unplug it (data cable), start the computer, when loaded to windows shut down again and plug the drive back in. Also try a different port if you can. Drives don't last forever and they are very cheap so if you can't get it to work get a new one.
1/5/2010 11:47:49 PM • Microsoft... • Answered on Jan 05, 2010
Reloaded xp by mistake
you can not undo a reinstall, you'll need to load the drivers from the oem cd or download them from the oem web site
6/9/2009 4:00:52 AM • Microsoft... • Answered on Jun 09, 2009
Media center doesn t start with remote
you have to install the media centers remote software
4/12/2009 1:21:09 PM • Microsoft... • Answered on Apr 12, 2009
I cannot access the SYSTEM RESTORE and the DISK ERROR CHECK funct
Open the Services applet via running a Microsoft Management console... Run - services.msc and make sure the System Recovery service is running. You may also need to temporarily disable Bit Defender. By the way, I don't think giving out your email address to a forum is a good idea.
4/7/2009 8:07:02 AM • Microsoft... • Answered on Apr 07, 2009
How do i recover deleted history
Not feasible then. Even with software it can be timely and complicated.
12/19/2018 2:01:30 AM • Microsoft XP... • Answered on Dec 19, 2018
2answers
Reinstall XP without losing my data
you can backup important files with an external USB adapter for your drive, you'll have to use a working computer to connect the drive from the other computer. When you are satisfied you have a backup, try the windows repair OR re-install windows xp using the "upgrade" option, it should leave all your files in place. Don't do a factory reset if you have that option unless you're sure everything important is backed up.
12/18/2018 6:53:32 PM • Microsoft XP... • Answered on Dec 18, 2018
Microsoft Windows XP Media Center Edition 2005 Logo
20 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
windows xp media center edition get
  • Computers & Internet
