20 Most Recent
Akira SV-4201 42 in. Plasma Television Questions & Answers
Vertical lines on the screen.
if you have to put your tv on channels 3 or 4 ,make sure its on 4,3 will introduce lines into the picture that scan up or down
The sound system is not
hi,
go to menu, surf for audio (sound) system selection. change the current setting and then try.
ok
I recently moved and somehow
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and Driver
downloads
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
When i turn my tv on it turns itself off aagain
This is a common problem I see almost every day in the shop, this is a switchmode power supply, sensing a "Fault" and shutting down the TV, to avoid, a fire or explosion. You need to get a "Quote" before proceeding with any repair and see if you wish to repair or replace.
What is the vertical i.c of akira?
Plasma sets do not have a "vertical IC". What is the problem you are having? If you can provide a description of the symptoms, we may be able to give you a solution.
Thanks,
Dan
Akira TV Problem
Now you will have to carry set to shop there is alot to reprogram in set in order to get it to re down load infromation.
