20 Most Recent
Samsung B7330 Cell Phone Questions & Answers
How to soft reset samsung b7330
Welcome to
FixYa
From your keypad Type #*7337#
or try this
to reset *2767*3855# or *2767*2878#
It will ask you to confirm, Press ok & if ask phone
code then Default phone lock
code for samsung if it did'not changed before then it is 00000000 (eight
zero's)
Further assistance i am here to help.
Thanks
Concerned:
Uxair Shah
Change language what can i do
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.OR:you can find in the settings>>phone settings>>language.hope this helps.if you need, and you don't have copy of the manual, let me know
My Phone all of a sudden has decided that the
i have a b7330 omnia pro..why it did not on. .when i charge it..it just has red light. .and i turn it on it just says..OMNIA pro B7330 and that it. .no start or wallpaper..somebody help me please. .??
How can i clean my
When using explorer,go to menu(right soft key) scroll down to option 9(tools) select the right scroll key to show drop down list. the list has the last item as 'options' select it. A new list appears the second item on it is Browsing History, open it and scroll to history and select clear.
Let me know how it goes.
Samsung b7330 hangs at Windows
1. Reset your device by press power button.
2. Put off the battery and put it on.
3. reinstall the room using by searching solution on Google (a lot)
good luck!
I tried installing some apps on my phone Samsung
let try for some Jad file to make sure the problem.. suggestion: use sktool to repair and maintain your phone then reinstall the jad file.. or reinstall the fresh Rom from Samsung web page. good luck
I locked it and forgot
just re install the software for your phone .
the problem will be solved
rate if it was helpful!!!
Hi i have a problem too, I have this phone samsung
download apps from a trusted site. www.getjar.com, www.mobango.com, www.zedge.com etc, dont forget to select the model of your phone while selecting an app. all the jar apps will not work on all devices.
