20 Most Recent
Nokia Inc 002L103 N97 Touch Screen phone Questions & Answers
My samsung corby pro(5310) touch
its because of touch screen IC which is conected with mobile CPU is short. it happen because of heavy use of touch screen with finger either then its pen stick. because in human body so many types of electron current is flowing and its enough to damage small IC of Touch Screen.
11/3/2010 6:44:48 AM •
Nokia Inc...
Answered
on Nov 03, 2010
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
Help me Forget nokia 1680c 2 .how fo do it? please
What do you mean by a 'restriction code'? If it is your password you might have to do a 'factory reset' on your phone.
If it has been locked with the IMEI code you will need to contact your network supplier to get them to unlock the handset.
