20 Most Recent
Taylor 1431 Digital Wireless Thermometer Questions & Answers
No display for outside temp. after replacing batteries.
If the unit was workingg prior to the battery replacement, you must remove the battery and check on the terminals to the battery. Make that these are clean, the battery is good - test using a multimeter- and replace with the correct postion.Now if the earlier battery had leaked it could have damaged the internal board and if so you need to open to check if the board is clogged with the battery leak. If so try and clean the board.
How to disable the alarm function on a Taylor weather station type wec-1502 ?
To disable the alarm function on your Taylor weather station type WEC-1502, follow these steps:
- Press and hold the "ALARM" button on the top of the unit until the alarm icon disappears from the display.
- Release the "ALARM" button.
- Press the "MODE" button on the top of the unit until the display shows the "CLOCK" mode.
- Press and hold the "ALARM" button again until the alarm icon disappears from the display.
Your Taylor weather station should now be set without the alarm function.
My Taylor we 1502 is showing HH in the outside relative indicator. How do I get it to recognize the outside relative humidity %? Thanks
If the outside temperature is currently displayed, there may not be anything wrong with the we 1502 sensor. The HH indicates that the outside relative humidity is above 95%; that is a limit of the sensor's detection/accuracy range. You could try moving your we 1502 sensor to a dryer area where it isn't exposed to rain/other falling water or wait until things dry out.
I hope this helps. Please add a comment with the model for the base of your weather system for more information. The HH message applies to most Taylor weather systems. The manual for the Weather Guide Indoor/Outdor 1731 system is available here: http://ecx.images-amazon.com/images/I/71QBC5RdcNS.pdf .
