20 Most Recent
Clarion VRX755VD Car DVD Player Questions & Answers
How u get video?
The parking brake (usually light green) wire from the stereo needs to rest at ground to view videos.
How to hook up to subwoofer?
You will need one pair of RCAs connected to the unit in the rear where it says "sub" and a remote turn (connected to the radios blue and white wire) on running from the radio(with the RCAs) to an amplifier. You will also need a power cable from the battery and a chassis ground coonected to the amp. Connect the subs (usually in some sort of enclosure) to the amp.
Cant find hand brake wire
i have the same model its the green wire next to the earth wire bottom row make sure u earth it otherwise the unit can be frustrating at times!!!!
Hi I have a brand
Try to turn off the radio first and then turn it back on then press the eject button repeatedly. If it still not working then the problem is with the radio itself. Give it back to the dealer where you purchased it, im sure that its still covered with the warranty since its brand new.
Have a blessed weekend.
No acciona la pantalla, no se desplega.
Hola.
Chequea el cable de alimentacion. Utiliza un Voltiometro para controlar si hay voltage. Si no hay corriente en el cable de alimentacion puedes necesitar cambiar el fusible de 15 amp incluido en el cable.
No sound on my Clarion
Disconnect all speakers and hook up one test speaker. If that works hook each speaker up one at a time and test each one.
I need a wiring diagram for my clarion vrx755vd
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
