20 Most Recent Microsoft Windows 2000 for PC Questions & Answers
2answers
Showing contents of a selection of folders in Windows
Assuming you want to copy entire folders hold down the control key and select each desired folder and then select copy or CTRL-C Go to desired location and select paste.
3/5/2018 12:52:54 AM • Microsoft... • Answered on Mar 05, 2018
Bad DirectSound driver. Error code 88780078
The sound card features might be turned off and causing Error Code: 88780078.
To activate these "features":
1)control panel
2)sounds and audio devices
3)Hardware tab
4)sound card should be listed... highlight... Properties
5)Properties tab
6)Audio Devices
7)highlight sound card and click Properties
8)If audio features are disabled... select "Use audio features on this device"
9)restart computer
6/23/2014 5:44:57 AM • Microsoft... • Answered on Jun 23, 2014
5answers
Windows 2000 login problem
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
6/11/2012 2:07:11 AM • Microsoft... • Answered on Jun 11, 2012
Win 2000 log in error
plz winodwo 2000 intsall me
6/3/2010 7:21:23 AM • Microsoft... • Answered on Jun 03, 2010
Download windows 2000 os
This thread
http://www.fixya.com/support/t4975329-find_windows_2000_drives_me
5/29/2010 6:03:28 PM • Microsoft... • Answered on May 29, 2010
I'm getting a boot error I/O 00001000 with my
I'd move on if I were you...but if you like pain...I can provide answers ;)
5/20/2010 4:10:24 AM • Microsoft... • Answered on May 20, 2010
Hi how do i get my old comp to run faster and
Add more RAM or upgrade the CPU
4/27/2010 5:22:20 AM • Microsoft... • Answered on Apr 27, 2010
Unable to install OS.
if you want to re-install OS try to do it in bios set up put set up your boot sequence to cd rom and save it and put the OS installer in cd rom and restart it and follow the next step there
i hope this can help you
3/29/2010 7:10:45 AM • Microsoft... • Answered on Mar 29, 2010
Hi how can i download windows2000 on to a cd-r
Hi!
I assume you have the source on your hard drive...
Carefully follow the instruction written HERE to make the source files into a bootable CD - and burn it!
If you don't have the source files anywhere, I can't help you get them - it'll be illegal! You can call Microsoft Support and ask for a new installation CD, given you provide them the info required to verify that you're a legitimate owner of that software!
Pelu.
3/14/2010 5:59:10 PM • Microsoft... • Answered on Mar 14, 2010
No sound
Hello...
Full details about sound issue in my website...
www.sureshayyar.110mb.com (Support page)
As an alternative u can do this (i am using this solution till date)
If u cant install the sound driver correctly, just buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get it in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available mfd from China, just plug and play on your USB port....
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
3/10/2010 10:46:32 AM • Microsoft... • Answered on Mar 10, 2010
Worm turning files into *.exe
hie dear,
this typy of infection causes due to a virus if we are using various types of mmc, mobile cards to a pc. u need to install an antivirus and if possible format ur pc first.
after installing the antivirus, always remember to scan the cards, pen drives and other devices before using.
if u want free antivirus then avira and avast are good.
bunty
5/5/2009 10:36:14 AM • Microsoft... • Answered on May 05, 2009
Network support for windows 2000
best network supporting for windows98,ringtopology u can use any softwear.
5/1/2009 7:38:07 AM • Microsoft... • Answered on May 01, 2009
Computer virus
4/5/2009 11:53:13 AM • Microsoft... • Answered on Apr 05, 2009
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
3/27/2009 8:29:57 PM • Microsoft... • Answered on Mar 27, 2009
Driver not kicking in dial up modem win 98
Sir,
Which modem.? also send me the which driver? i will send back you link for free download. Plz tell me the exact software name.
Thanks Good Luck
Appreciate to rate as "Fixya"
3/11/2009 5:54:28 AM • Microsoft... • Answered on Mar 11, 2009
It starts up fine until a blue screen pops up
hi
i think one of the drivers are the culprit. heres what you should do:
open your system unit and remove all the pci cards except the vga card. and turn on the computer.if it starts fine, then turn it off and hook each card one by one.
hope this helps
Kind regards
RAhL_hunk
3/10/2009 1:50:14 AM • Microsoft... • Answered on Mar 10, 2009
I try to boot my computer from a windows 98 disc, but it won't lo
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
3/8/2009 8:20:20 PM • Microsoft... • Answered on Mar 08, 2009
File sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
9/7/2008 5:37:15 PM • Microsoft... • Answered on Sep 07, 2008
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
Microsoft Windows 2000 for PC Logo
22 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
download windows 2000 os
  • Computers & Internet
