20 Most Recent
MXL Acoustica MVS Mixcraft 6 Vocal Studio USB Microphone Pac Questions & Answers
My marshall MXL V67 MIC doesn`t work
If this is a condenser micrphone it will require Phantom Power from the mixer you are trying to use it with. If Phantom Power is provided, check the cable to ensure proper wiring.
1/24/2015 11:10:45 PM •
MXL Audio...
Answered
on Jan 24, 2015
Does djx750 use phantom power
F rom what I see in the user manual no, only a dynamic mic can be used with this unit. A comdenser mic will not be powered.
1/24/2015 11:07:35 PM •
MXL Audio...
Answered
on Jan 24, 2015
Is there a battery in a mxl 992?
Has it a remove able cover or on the plug? Normally it has the word "Electret condenser" on the body. Is it a lapel type ? Modern units are invariably of this type.
6/29/2014 5:17:39 PM •
MXL Audio...
Answered
on Jun 29, 2014
The sound is really low, it only works for 3
are u sure the type of mic ur using is made for phantom power? if it is. try opening up the gain on the sound board just a tad. if that doesnt work turn the master slider up. try other mics and see if it isnt ur soundboard or speakers
10/18/2011 7:43:04 AM •
MXL Audio...
Answered
on Oct 18, 2011
I just took my MXL
This microphone requires 48v Phantom power. So if you are trying to connect it to your computer, you will need to use a USB interface that will provide phantom power. If you are connecting it via a mixer, make sure Phantom power is switched on if it is available. As the MXL 3000 is only available new from Guitar Center or Musicians Friend, they can also provide you with what else you need.
10/4/2011 11:59:25 AM •
MXL Audio...
Answered
on Oct 04, 2011
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
