20 Most Recent
Xerox Phaser 6280 Clr Laser Printer 26Ppm 256Mb UsbEnet Taa Compliant Questions & Answers
Xerox phaser 6280
1. Power device off
2. Leave off for 2 minutes
3. Power device on and test.
If error code displays again you will need to place a service call.
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Xerox workcentre 3345 paper jam in tray1
If you've modified one of the trays and still encounter the same error, it's worth checking if there are any obstructions in the paper path or if the default paper type and color settings need adjustment.
Remove Jammed Paper From Tray 1:
First, remove any paper from the Bypass Tray.
Grasp both sides of the Bypass Tray and pull it straight out of the printer.
Next, pull out Tray 1 until it stops. To remove the tray, lift the front of it slightly, then pull it out of the printer.
Check for any jammed paper and remove it.
Also, make sure there's no crumpled paper left in the tray or jammed inside the printer.
If you have Tray 2 (optional), check it as well.
Insert Tray 1 back into the printer and push it all the way in.
Fully insert the Bypass Tray as well.
Confirm the paper settings if prompted.
Try your job again.
Power the Printer Off then On:
Press the Power/Wake button on the printer control panel.
Choose "Power Off" to turn off the printer.
Wait for a few seconds, then press the Power/Wake button again to turn it back on.
Retry your print job.
Replace the Paper Feed Roller (if needed):
If the issue persists, consider replacing the paper feed roller. Refer to your printer's documentation for instructions on how to do this.
If the problem continues, contact Xerox support.
How Do I Reset Counters of Xerox Workcentre 7435 Toner Chips ?
You can't. It is hard wired in programmed memory. The reason is because most Xerox printed are supplied on a consumables deal where you have to buy toner direct at a slightly inflated price to cover the lowered lease cost of the machine. These machine also 'phone home' for interrogation..
