20 Most Recent
Power Privilege and Law : A Civil Rights Reader Questions & Answers
I have been hit in the back by the same person 4 times when I turn in angre they say what are you going to do about it where both adults
It is a bullying tactic. It's tough to deal with someone like this. Some may disagree, but you may have to stand up to the person and return the aggression. Let them come up behind you and then back into them really hard like you didn't see them, or turn really quick with an elbow out so you make contact, and claim it was an accident. Eventually, the person is going to stop coming up behind you and pushing you. Or they are going to become even more aggressive. Be prepared to stand up for yourself.
But don't let their immaturity drag you down.
I stay with my wife for 21 years on her fathers
Are you or were you ever married?, If so get an attorney. If not read about common law.. If you lived in the same dwelling with your ex for more than seven years then you are entitled to more than you think. Sorry to hear good luckhope this helps
I bought a fryer from poundstretcher 9 months ago
Depends on what you paid for it. If it was less than 20 pounds you may only expect it to work for a limited period, if you paid more than 30 pounds you would expect it to work for at least a year or more. Return it to the shop and say it is unfit for purpose and not of merchantable quality. The decision is down to the shop but if they do not want to agree to a replacement or a refund (possibly minus some money for nine months of use), report them to trading standards.
If a partner in a de facto relationship claims her
From results in Australian law she (or he) has excellent rights to get fair share of the property ,income ,superannuation and any other finances that were the property of the partner before the relationship began. Only here it is not three years but 6 months
I have the IQ 4522DJBT bluetooth speaker and i am having trouble charging my unit how do you know when its your power cord.
- Check the power cord for visible damage: Look for any frayed wires, cuts, or broken connections. If you find any damage, the power cord will need to be replaced.
- Try a different power source: Plug the speaker into a different outlet or power source to see if the issue is with the outlet.
- Use a different power cord: Try using a different power cord to see if the issue is with the cord that came with the speaker.
- Check the charging port: Make sure the charging port on the speaker is not damaged or obstructed. Clean it if necessary.
If these steps do not resolve the issue, the problem may be with the speaker itself and it may need to be repaired or replaced
MultiCat Litter Box by LitterMaid won't turn on.
- Check the power source: Make sure that the power cord is securely plugged into an outlet. Also, check if the power outlet itself is working by plugging in another device.
- Check the power switch: Ensure that the power switch on the litter box is in the "on" position. Sometimes it can accidentally get switched off.
- Reset the litter box: Unplug the power cord from the outlet and wait for about 60 seconds. Then, plug it back in and try turning it on again. This can sometimes reset any issues the litter box might be experiencing.
- Replace the batteries: If your MultiCat Litter Box by LitterMaid is battery-operated, check if the batteries need to be replaced. Even if it is plugged into an outlet, the batteries might still be required for backup power.
- Check for any obstructions: Inspect the litter box for any debris or waste that may be blocking the mechanism or sensors. Clear any obstructions and try to turn it on again.
- Contact customer support: If none of the above steps work, it's recommended to reach out to LitterMaid's customer support for further assistance.
