20 Most Recent S. C. Johnson & Son Scrubbing Bubbles Automatic Toilet Bowl Cleaner Twin Pack Refill Fresh Scen Questions & Answers
We have 2 scrubbin bubbles shower cleaners.
Try using a pencil eraser on each battery contact. That usually fixes it.
3/18/2011 6:18:58 PM • S. C. Johnson &... • Answered on Mar 18, 2011
We just replaced our Scrubbing bubbles automatic
I've found that the batteries lose contact after w while, so here is what I do:
1) take a pencil eraser and rub each of the contacts with it.
2) lightly apply some petroleum jelly to each end of the battery.
3) make sure the compartment is completely dry. Take a small piece of paper towel, roll it up, and, with the pencil, rub the inside of each of the battery compartments.
4) re-insert batteries and try again. It should work!
1/22/2011 3:12:14 AM • S. C. Johnson &... • Answered on Jan 22, 2011
Mabe Aqua Wash light blinking?
This is not a machine that we know in North America. https://www.google.com/search?q=Mabe+aqua+wash+light+blinking ..
4/25/2024 12:07:53 AM • Washing Machines • Answered 7 hours ago
How do I remove the whole trimmer head from a Craftsman 358-745460 trimmer? This is an electric trimmer with a red plastic hexagon in the middle of the trimmer head.
You have to take the lower case apart to reach the back of the shaft which is slotted it has reverse threads
4/23/2024 3:26:26 PM • Washing Machines • Answered Yesterday
CH slider on potterton programmer ep2002 broken can I get a spare or do I need a new programmer?
If you're looking for a direct replacement for the broken slider, you might be in luck. The Potterton EP2 Programmer is now the official replacement for the EP20021. It's designed to fit the existing backplate without any rewiring, provided the backplate is undamaged and in good condition. EP2 replacement programmer for EP2002 (plumbersforums.net) The EP2 doesn't have the additional terminals that the EP2002 had (which allowed it to function as a mini-wiring center), but the core wiring should match. So, if your EP2002 was acting as a wiring center, you might need to check if the EP2 accommodates all your existing wires. Considerations: Since you're controlling your central heating (CH) via a Netatmo 'smart' thermostat and manually managing hot water (HW), the EP2 might suit your needs. The CH slider permanently on and HW controlled separately aligns with your current setup. Keep in mind that the EP2 doesn't have the extra features of the EP2002, so assess whether those additional terminals were crucial for your system. Installation: Replacing the programmer involves turning off the power, unscrewing the old one, and attaching the new EP2 to the existing backplate. Remember to reuse the little red 'LED' cover from your old programmer3. If you're comfortable with basic soldering, you could also replace the tiny NiCad battery inside the EP2002 to see if that resolves any issues. Budget-Friendly Option: While the EP2 typically costs around £65-70, you might find a better deal on platforms like eBay3. Just ensure it's compatible with your existing setup. Remember to turn off the power before any installation work.
4/22/2024 5:12:55 PM • Washing Machines • Answered 2 days ago
Tecno front load washing machine model : TN-312 E01 Error Code problem
Ttypically indicates a problem with the water supply. Troubleshooting: Clogged Inlet Valve: The inlet valve controls the water flow into the machine. If it becomes clogged, the machine won't fill with water, resulting in the E1 error. To address this: Turn off the washer and unplug it. Remove any debris blocking the inlet valve. Brush it with distilled white vinegar. Reattach the water valves and turn on the power to the washer. If the issue persists, consider replacing the inlet valve. Failed Inlet Valve: If the inlet valve has failed, it needs replacement. Check for water leaks to identify a failed inlet valve. Pressure Switch Hose: A damaged or clogged pressure switch hose can also trigger the E1 error. Follow instructions to clean the pressure switch hose. Water Level Sensor: The water level sensor detects water levels in the machine. If it's malfunctioning, the E1 error may appear. Test the sensor using a multimeter after unplugging the machine and removing the control panel. Note the divergent possibilities below. Because of this, you may have to seek professional assistance. https://theportablelaundry.com/how-to-fix-the-e1-error-on-washing-machine/ Understanding E01 Error: What Does E01 Mean on a Washing Machine? - Washing Machine Blog
4/20/2024 9:37:09 PM • Washing Machines • Answered on Apr 20, 2024
Defy twin tub 1300 brake cable snapped
Confirm the cable snapped. Replace the cable if so. You can check the owner's manual or contact Defy service centers for the correct part. New Defy Customer Service number is : +912269181919 Install the new cable by following the reverse steps of removal. Make sure it's securely attached. After replacing the cable, test the machine by running a wash cycle to ensure that the brake engages and disengages properly. If everything works as expected, you've successfully fixed the issue. https://www.manualslib.com/manual/2077795/Defy-Twinmaid-1300.html
4/20/2024 9:28:08 PM • Washing Machines • Answered on Apr 20, 2024
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0". If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
4/19/2024 3:06:17 AM • Washing Machines • Answered on Apr 19, 2024
Balance systems or shocks broken. GE Spacemaker has broken stabilizers.
GE Spacemaker is a generic range of appliances. All questions in Fixya need full 'make model (what it is)', first 3 words. If the stabilizers are broken Google for parts. GE (numerical model number) Parts https://www.google.com/search?q=GE+spacemaker+parts Depending on age, they may no longer be available ..
4/15/2024 7:28:59 PM • Washing Machines • Answered on Apr 15, 2024
Dear sir, I have Primus MB205 washer extractor problem. It shows error out of order, ask for service (error 301: mits 0c2)
Question edited for spelling. You will have to do what it says and call for service. This is a Commercial Machine and not popular in North America where we are. https://www.google.com/search?q=primus+mb205+washing+machine The error is not listed anywhere https://www.google.com/search?q=error+301+mits+0c2 ..
4/14/2024 5:20:05 PM • Washing Machines • Answered on Apr 14, 2024
WASHER EXTRACTOR PRIMUS MB205 OUT OF ORDER SHOW ASK FOR SERVICE ERROR 301 MITS. 0C2
Code 301 relates to a drain failure. The rest of the code may relate to specific parts. I find no explanation available for the remainer of the code. It is likely only the manufacturer can say what that refers to. https://primuslaundry.com/en/contact
4/14/2024 11:12:07 AM • Washing Machines • Answered on Apr 14, 2024
Lay out of water tubes. I have taken apart but forgotten the layout DDS04 E01
See page 13 of the user manual. screenshot 2024-04-14 at 10.54.12-undefined-undefined-0.png
4/14/2024 9:55:10 AM • Washing Machines • Answered on Apr 14, 2024
2answers
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error. Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract. If the fan is working then it's probably an inverter.
4/10/2024 5:59:51 PM • Washing Machines • Answered on Apr 10, 2024
Hayward 250 HD. Control panel does not display the temperature.
I am sure I answered this yesterday? You posted to washing machines category and this appears to be a gas fueled pool heater. You would be best contacting a service engineer because it is gas powered, although if it does blow up, it is outside or will only blow up the pool house.
Universal H-Series Natural Gas 250000 BTU Low NOx
Hayward Pool Products https://hayward.com > universal-h-series-natural-gas-250... Universal H-Series Natural Gas 250,000 BTU Low NOx. Hayward. SKU: W3H250FDN. Service and diagnostics manuals https://www.google.com/search?q=hayward+250+hd+service+manual ..
4/9/2024 5:23:09 AM • Washing Machines • Answered on Apr 09, 2024
2answers
Installing transit bolts
advise you take the top off so you can see where the bolts locate
4/7/2024 9:51:13 PM • Washing Machines • Answered on Apr 07, 2024
IG IGNIS 105 LA washing machine does not show and light after a low voltage run and power surge. please guide where to look into. I am located at a remote area in Nigeria.
If your IG Ignis 105 LA washing machine does not show any lights after a low voltage run and power surge, check the power supply, main control board, and internal fuses for damage. Consider contacting IG Ignis customer support for remote troubleshooting guidance or arranging for a technician to inspect and repair the appliance.Hi Tracey and welcome to JA, sorry for the delayed response, flat out all day here,, The clicking sound you speak of, is it coming from the door latch/catch area of the cabinet,, Can you lean down for me, seta wash program and listen very closly and pin point the origin of the clicking sound,, It will either be near the door handle on the door, or behind the control panel ok, Cheers. f3zblyr-undefined-undefined-0.jpg
4/7/2024 1:25:54 PM • Washing Machines • Answered on Apr 07, 2024
S. C. Johnson & Son Scrubbing Bubbles Automatic Toilet Bowl Cleaner Twin Pack Refill Fresh Scen Logo
5 questions posted
Top S. C. Johnson & Son Washing Machines Experts
john h
Are you a S. C. Johnson & Son Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • S. C. Johnson & Son Washing Machines
Most Popular Question
just replaced our scrubbing bubbles
  • Washing Machines
