20 Most Recent
Whirlpool Duet Front Loading Dryer Rack W10121663 Questions & Answers
My whirlpool duet dryer made a funny burning smell
Hi
I
believe if the belt is fine then it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine and the belt is also fine, then it
can be due to the motor or the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a
link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC
TEST MODE
1. Make sure that the dryer is in the "Standby"
mode (plugged in and all of the indicators
are off).
2. Press the following control panel keypad
sequence all within 5 seconds:
More Time-Less Time-More Time-
Less Time.
3. All indicators on the console should now
be illuminated with "88" showing in
the "Estimated Time Remaining" display,
if this test mode has been entered successfully.
I have a whirlpool duet dryer.. I need to know how
Hi dear.Here is some help from the user manual.I hope that helps.Thanks.
DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2. Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3. Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4. Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
How do i get a necklace stuck in holes of my Whirlpool thin twin washing machine?
It won't be easy - the necklace went through the hole so logically it should come back, unfortunately it is the nature of a necklace to be a random structure unless some tension is applied; the links or whatever are apt to go sideways and jam in the hole. In an extreme case the necklace could be knotted...
If it is knotted there is no chance of removal and the solution is either to dismantle the washer or to break the necklace.
Positioning the drum so the necklace is under tension under its own weight and with some jiggling and the application of lots of patience and some luck it should come back through the hole.
4/7/2024 3:13:20 AM •
Whirlpool...
Answered
on Apr 07, 2024
Whirlpool heavy duty commercial washer # cae2743800 will not start after coins inserted and start button held
Check the Coin Mechanism:
Ensure that the coin mechanism is functioning correctly. Sometimes, coins may get stuck or not register properly. Verify that the coin slots are clear and that the mechanism is engaging properly.
If there's an issue with the coin mechanism, it could prevent the washer from starting. You might need to clean or repair it.
Inspect the Wiring:
There should be a harness with two wires that go into the coin mechanism box. Check if these wires are intact and properly connected. If you find any damage or loose connections, consider repairing or replacing the wiring.
Bypass the Coin Mechanism:
If you suspect that the coin mechanism is causing the problem, you can bypass it temporarily.
Cut the wires going into the coin mechanism and insert a push button switch in the line. This will allow you to manually start the washer without relying on the coin mechanism.
If you're unsure how to do this, consider contacting a local repair shop for assistance.
Check for Other Issues:
Inspect other components such as the lid switch, control board, and start button. Any malfunction in these parts could prevent the washer from starting.
Make sure the washer is plugged in and that there are no tripped circuit breakers or blown fuses.
4/3/2024 3:28:33 AM •
Whirlpool...
Answered
on Apr 03, 2024
