20 Most Recent NEC VT465 Multimedia Projector Questions & Answers
Where can I buy a new filter for a NEC VT465 projector
Contact the authorized service center for NEC. If you know the part number to it (refer its repair manual), you can buy it online from www.alibaba.com/ Electro help
7/23/2014 5:40:09 AM • NEC VT465... • Answered on Jul 23, 2014
0answers
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
4/9/2014 4:04:03 AM • NEC VT465... • Answered on Apr 09, 2014
The power light is yellow and status light yellow
it seems the lamp is failing ,the price of the lamp is USD130 any questions, feel free to contact me have a nice day! Jerry,Lampdeng Limited
3/17/2014 3:17:13 AM • NEC VT465... • Answered on Mar 17, 2014
Infocus projector is showing upsidedown
Sounds like you have to scroll thru the video settings upside down is the setting for projectors mounted on the ceiling simple fix though you may have to stand on your head to read the setting options :0)
8/23/2013 12:46:26 AM • NEC VT465... • Answered on Aug 23, 2013
2answers
Nec projector not coming on
Yep, there is a switch that enguages the lapm cover is opened, put the lamp cover back in place and the status blinking red light will stop, and projector will be ready.
1/9/2013 4:25:11 AM • NEC VT465... • Answered on Jan 09, 2013
My projector has blue lines
I would recommend that you clean the lens.
3/23/2011 4:24:27 PM • NEC VT465... • Answered on Mar 23, 2011
I replaced the projector lamp
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
2/10/2011 5:43:08 AM • NEC VT465... • Answered on Feb 10, 2011
I HAVE 2 NEC VT465
hi,
go to picture adjustment menu and select tint adjustment according to ur preference.
ok
12/17/2010 5:18:39 AM • NEC VT465... • Answered on Dec 17, 2010
Blotchy uneven purple in the
This is a delamination of one of the LCD panels, requires factory authorized service.
8/15/2010 10:26:47 PM • NEC VT465... • Answered on Aug 15, 2010
I can't see my entire
Adjust the screen size in the menu section.
8/10/2010 4:17:33 AM • NEC VT465... • Answered on Aug 10, 2010
Font on screen is purple, font in powerpoint is
colour decay gives
5/8/2010 3:40:04 PM • NEC VT465... • Answered on May 08, 2010
I mounted my In Focus Projector upside down
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
9/28/2009 2:19:16 AM • NEC VT465... • Answered on Sep 28, 2009
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
8/31/2009 9:39:27 AM • NEC VT465... • Answered on Aug 31, 2009
Reset a projector nec 575
If you mean the lamp timer, hold the help button on the remote for 10 seconds
7/26/2009 11:10:30 AM • NEC VT465... • Answered on Jul 26, 2009
My NEC VT465 shows a transparent yellow spot in the middle of the projected image.
I lent mine to a friend and it came back with this same problem - my guess is they wiped the lens with a solvent that messed up the lens coating the only solution is to get a new lens
7/26/2009 3:40:17 AM • NEC VT465... • Answered on Jul 26, 2009
NEC VT465 Multimedia Projector Logo
32 questions posted
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Office Equipment & Supplies
Most Popular Question
mounted in focus projector upside down
  • Office Equipment & Supplies
