20 Most Recent
NEC VT670 Multimedia Projector Questions & Answers
Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
11/25/2018 7:02:43 PM •
NEC VT670...
Answered
on Nov 25, 2018
LINES PROBLEMS
You should check any loose cable connections to your projector. I'd also check the signal type coming into the projector. Is it HD? Is it digital or analog? Is it from a computer? I would need you to be more specific.
-GWOOD
7/18/2014 7:33:08 PM •
NEC VT670...
Answered
on Jul 18, 2014
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
9/4/2012 12:37:33 AM •
NEC VT670...
Answered
on Sep 04, 2012
The whole projection is yellow in colour and we
I can possibly save you from having to call someone in.
2 things that you should check before you have someone called in to look at your projector.
1. Color correct in the system menus, you can individually adjust the color levels in this menu. Increasing and decreasing the values can help relieve the yellowness presented.
2. If at all possible, buy a replacement bulb for your projector and if it doesn't work, simply return it.
5/31/2011 7:27:02 AM •
NEC VT670...
Answered
on May 31, 2011
Can i transmit a tv
yes you can, but not "through" your tv, unless your tv had component video outputs. you should run a component cable from your cable box directly to your projector, or do what i did and buy a multimedia reciever/surround sound system and run it to that then split it from that to your tv and your projector.
5/3/2011 2:00:36 PM •
NEC VT670...
Answered
on May 03, 2011
How to clean filter for overhead projector?
use a vacuum cleaner to **** the dust out of the filter unit on the right side rear end of the projector (right side up directions).
Then reset the filter timer.
MENU, DEFAULT, CLEAR FILTER USEAGE
4/19/2011 9:41:49 AM •
NEC VT670...
Answered
on Apr 19, 2011
