20 Most Recent NEC VT676 Multimedia Projector Questions & Answers
When I turn on my NEW projector it has a blue pixelated screen. Does this mean I need a new bulb?
if it projects than bulb lit and working your not getting any viedo input
8/16/2016 3:59:28 PM • NEC VT676... • Answered on Aug 16, 2016
Status light blinks red bulb replaced only 2 months ago
you need to reset the lamp timer
8/15/2014 11:34:03 PM • NEC VT676... • Answered on Aug 15, 2014
0answers
NEC VT676 I have tried numerous new bulb in
yskxr
9/24/2013 10:31:51 PM • NEC VT676... • Answered on Sep 24, 2013
When using the computer with my projector my computer goes blank because i am not actively using it just having students view the screen what can i do
"test test" offers a good answer but misses out the possibility that your laptop "Power Settings" might be turning off your screen display. So if the problem persists after going through all the things already suggested you could go to your laptop's control panel to the Power Options and click on "Change when to turn off the display". Good luck.
9/8/2012 12:18:02 PM • NEC VT676... • Answered on Sep 08, 2012
I get a red light then 3 beeps then an orange
Hello
There are tow possibilities for this fault. The first one is with its cooling fan. Check whether the fan works as soon as you switch on. It must turn ON as soon as the power is ON. Blinking Orange is an indication about this fault. According to you, your projector comes with red light and then beeps and the orange and finally haults.
Check the red light for its blinking time. [1] If it is in the order [one cycle (0.5seconds ON, 2.5seconds Off) - Denotes lamp cver error or lamp housing error _ [Replace the lamp cover of lamp housing correctly]
[2] 2 cycles (0.5 seconds On, 0.5 seconds Off) denotes the temperature error _[ The projector is overheated. Move the projector to a cooler location.
[3] 4 cycles (0.5 seconds On, 0.5 seconds Off) denotes Fan error. Check the fan.
[4 6 cycles ( 0.5 seconds On, 0.5 seconds Off) denotes Lamp error. Lamp fails to light up. Wait a full minute and turn ON again and check.
There is some fault with its cooling fan or lamp. The orange denotes the set comes to standby after detecting a fatal fault and give you a Beep sound. If the lamp inverter has damaged, this kind of fault will occur. Lamp will not light up, and projector will give you a fault indication both with sound and light.
Anyway, it needs a keen attention in service. OK
9/20/2011 2:10:10 PM • NEC VT676... • Answered on Sep 20, 2011
What does a solid red status light on a NEC VT676
This could be a number of things. When I encountered this problem it was simply a burned out lamp. If you have not checked that make sure you do that first. Also there is a safety feature on the projectors that will not let you turn the projector on until the lamp cover is back in place. You may also want to ensure that the filter door is securely in place. After you have done this try to power up the projector (it will take a few seconds for the lamp to warm up.) If the projector starts up, go to the menu and clear the lamp hours. These projectors have lamp life's that will expire after a certain amount of time, irregardless of the functionality of the bulb. Hope this helps you out. :)
6/2/2011 2:02:10 PM • NEC VT676... • Answered on Jun 02, 2011
2answers
Lamp error on nec projector
Have you changed the lamp? is so check out fixmyprojector.com
the ballast most likely needs to be replaced
8/11/2010 1:48:17 PM • NEC VT676... • Answered on Aug 11, 2010
3answers
NEC LT280 lamp error.
This is a Common Error on these Models. How old the Lamp is?
Replace the Lamp. Most of the times, when Lamp is at fault, this would Happen.
If after replacement of Lamp, Problem persists, then we need to Inspect and Test Other Components or then, you could ring a Local Serviceman in your area.
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
5/6/2010 12:20:32 PM • NEC VT676... • Answered on May 06, 2010
Power light is steady orange and lamp light is red
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
4/21/2010 3:05:10 PM • NEC VT676... • Answered on Apr 21, 2010
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
4/21/2010 2:52:15 PM • NEC VT676... • Answered on Apr 21, 2010
Hello there,
lamp error. either the lamp is bad or the ballast is.
1/27/2010 4:02:08 PM • NEC VT676... • Answered on Jan 27, 2010
2answers
NEC VT676 lamp error
indicating ballast unit problem
4/22/2009 12:23:35 PM • NEC VT676... • Answered on Apr 22, 2009
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
4/8/2009 7:18:32 PM • NEC VT676... • Answered on Apr 08, 2009
NEC VT676 Multimedia Projector Logo
37 questions posted
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Office Equipment & Supplies
Most Popular Question
lamp error nec projector
  • Office Equipment & Supplies
