20 Most Recent
Samson Xm910 8Channel Powered Mixer 900watts Questions & Answers
No audio out
Here is an online manual for it, can't find a download though. Hope it helps.http://www.manualslib.com/manual/143781/Samson-Xm910.html
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
When I turn on the
Sounds like the amp is going into a protective mode.
Make sure your outputs aren't shorted.
If you're into electronics, look for bulging electrolytic capacitors or blown transistors.
Something is tripping the safety in the unit!
Power cord for sampson xm910
The power cord is a standard one used on almost all tower computers... A good source of the cord is at thrift stores... they usually have them by the dozens... Also any computer store or Radio Shack has them.
How do i connect dis
First of all a link to the manual:http://s3.amazonaws.com/samsontech/related_docs/XM910_ownman_v1.pdf Have a look at page 14, 9. Go out of MixOut ( line level ) into any line level auxiliary inputs left and right on the other mixer. You didn't say what the other mixer is so this is the easiest. What you will have is a sub mix of everything plugged into the Samson controllable by the controls for the line in you are using on your second mixer. There are other options which you should be able to discover by reading your manual for the Samson and the manual for the other mixer.
Left side amp not working
There is usually a fuse, but if it were bad, the whole unit would be down. Since the right side is working, at least the troubleshooting will go faster. Take it in to a TV or Audio repair shop and get an estimate. Getting more than one estimate is always a good idea.
Good luck, and hope this helps.
What is the likely cause of the phantom power of a
The phantom power is used for condenser mics. MAKE SURE you do not plug in other mics or devices that do NOT have balanced, isolated outputs as they will short out the phantom power to others.
You should find between 15 and 48 volts between BOTH pins 2 and 3 of each mic connector when measured to pin 1 of the connector. There is about 6K ohms impedance from the phantom supply to pins 2 and 3.
IF you have an accident and connected high voltage to pin 2 or 3 it COULD back up and blow the bypass cap for the 48 volts.
Please note: ALWAYS power ANY interconnected equipment from teh SAME receptacle to avoid damage due to ground bounce in the event of a fault in a piece of equipment.
Samson MDR8 blowing internal power supply fuses.
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
3/17/2010 3:16:09 PM •
Samson Music
Answered
on Mar 17, 2010
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
