20 Most Recent Minolta Freedom Zoom 90 Date 35mm Point and Shoot Camera Questions & Answers
Any websites offer free downloadable camera
try google 'camera manuals' and you'll get plenty options
8/18/2009 9:06:17 PM • Minolta Freedom... • Answered on Aug 18, 2009
Minolta Freedom Zoom 90 Camera will not flash
Common problem.
Flash transformer needs replacement.
4/2/2009 10:12:51 PM • Minolta Freedom... • Answered on Apr 02, 2009
I bought a replacement battery door for my minolta dimage z6 camera but cannot figure out how to remove the old one can you help
Where i buy the minolta dimage z6 battery door in tamilnadu india
4/5/2024 1:29:59 AM • Minolta Cameras • Answered on Apr 05, 2024
My Minolta Freedom Zoom 70C camera will not take pictures.
Try cleaning the contacts in the camera and clean the film canister. You can also try putting self adhive tape on the DX Area of the film cassette and set the film speed ASA manually. What is the DX code on a film roll? The DX code is the silver and black pattern on almost every film cartridge. Inside most electronic film cameras, there is a series of metal pins that read the code and tell your camera what your film speed is.
Film DX-code sticker - Decisive Moment
You are the only person to encounter this issue, so you may need professional repair. https://www.google.com/search?q=Minolta+Freedom+Zoom+70C+not+reading+DX+Codes ....
7/11/2023 11:43:51 PM • Minolta Cameras • Answered on Jul 11, 2023
Minolta 460TX. Repair the flash on this camera?
Question edited for clarity. Did you replace the flash battery? Were the contacts clean and not corroded? They need professional repair https://www.google.com/search?q=Minolta+460TX.+Repair+the+flash ..
3/21/2023 1:45:49 AM • Minolta Cameras • Answered on Mar 21, 2023
2answers
How to fix minolta weathermatic a power problem
Are the batteries the right way up ? Is there corrosion within the battery chamber ?
2/27/2023 4:20:37 PM • Minolta Cameras • Answered on Feb 27, 2023
Minolta 404si Dynax doesn't shoot
It sounds like you may have an issue with the shutter mechanism, most likely caused by a worn out or dirty shutter. I would recommend taking it to a professional camera repair shop to have it checked out. They may be able to diagnose the issue and repair it or, if necessary, replace the shutter. If you are not comfortable with taking it to a professional, you can try to diagnose the issue yourself by taking a few test shots with the camera on a tripod in different lighting conditions. If you are able to get some consistent results (e.g. the shutter always fails to fire at the same point or in the same lighting conditions) then you may be able to narrow down the problem and focus your troubleshooting efforts.
12/26/2022 12:36:08 AM • Minolta Cameras • Answered on Dec 26, 2022
How to fix Minolta Freedom Zoom 125 Camera that wont turn on with the 'On' button.
Remove the battery and check it for voltage with a multimeter. The drop may have caused internal damage to one of the cells. This link shows that 'Freedom Zoom' is a generic series for Minolta and is not an actual model. I was trying to see what form the battery took. If it is the Duracell lithium 123 battery, they should each read 3 volts on the meter. https://www.google.com/search?q=Minolta+Freedom+Zoom+battery ..
12/17/2022 6:30:35 PM • Minolta Cameras • Answered on Dec 17, 2022
Minolta 500si autofocus stopped working. Tried turning manual focus on and off, restarting, resetting, putting new battery in. Not sure why it isn't sensing the autofocus lens attached. Any ideas?
Try gently cleaning the electronic contacts on the camera body and the rear of the lens, without touching the rear lens element or the mirror in the camera.
1/12/2020 12:00:48 PM • Minolta Cameras • Answered on Jan 12, 2020
What is my Minolta weathermatic 10 x 42 worth?
To whom ? Yourself or a prospective purchaser ? Anyway, Fixya does not provide valuations of equipment, even when posted in the correct forum.
7/29/2019 10:46:55 PM • Minolta Cameras • Answered on Jul 29, 2019
Finding the software to download pictures from my minolta dimage Z3 camera to the computer
Check your 'C' drive on PC. The path to the software will either be C:\Program Files\ or C:\Program Files (x86) if you have installed it. If you need to find appropriate software, contact Konica Minolta, its usually a free download for you to install.
5/19/2019 9:11:04 AM • Minolta Cameras • Answered on May 19, 2019
I am in the UK and need to know if my Minolta Dimage F200 will take a larger than 2GB SD card.
  • Memory Card Form FactorSD Memory Card
  • Included Memory Card Capacity 16 MB
  • Memory Card Slot SD card
  • Supported Memory Cards MultiMediaCard, SD Memory Card
Supported memory cards do not appear to be more than SD. To get above 2GB the supported memory card type should include SDHC.
5/19/2019 9:06:54 AM • Minolta Cameras • Answered on May 19, 2019
Found minolta Dimage7i in back of parent's storage cabinet. batteries left in have leaked on the hinged door and would like to replace to see if camera will still work. great shape.
Put on proper protection for your skin/eyes, then remove the old ones, clean with some general cleaner or cola(yes like Coca Cola or Pepsi, etc. as it eats corrosion), then replace the batteries with new ones and see what happens!
3/24/2019 6:13:55 AM • Minolta Cameras • Answered on Mar 24, 2019
Al 1000 manuals
Most lens have a red spot on them. There is usually a red spot on camera (look on left side). The one on camera body is the unlock and needs to be pushed and held in as you rotate lens red spot towards the camera spot. When they line up you can remove lens. ?
10/21/2018 12:15:06 PM • Minolta Cameras • Answered on Oct 21, 2018
Minolta Freedom Zoom 90 Date 35mm Point and Shoot Camera Logo
Popular Tags
9 questions posted
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
Minolta Cameras
  • Minolta Cameras
Most Popular Question
minolta freedom zoom 90 camera will not
  • Cameras
