20 Most Recent
Minolta Freedom Action Zoom 90 35mm Point and Shoot Camera Questions & Answers
Won't take picture though I replaced battery.
Even though it was cushioned somewhat the camera took enough damage to jam something. The flashing symbols are a generic error code it could mean the shutter, zoom, film transport, flash, or some combination of these system are not working (sorry but without tearing the camera apart I can't narrow the problem any further)
Minolta 404si Dynax doesn't shoot
It sounds like you may have an issue with the shutter mechanism, most likely caused by a worn out or dirty shutter. I would recommend taking it to a professional camera repair shop to have it checked out. They may be able to diagnose the issue and repair it or, if necessary, replace the shutter.
If you are not comfortable with taking it to a professional, you can try to diagnose the issue yourself by taking a few test shots with the camera on a tripod in different lighting conditions. If you are able to get some consistent results (e.g. the shutter always fails to fire at the same point or in the same lighting conditions) then you may be able to narrow down the problem and focus your troubleshooting efforts.
Al 1000 manuals
Most lens have a red spot on them. There is usually a red spot on camera (look on left side). The one on camera body is the unlock and needs to be pushed and held in as you rotate lens red spot towards the camera spot. When they line up you can remove lens. ?
