20 Most Recent
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Questions & Answers
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck. If you need further help, reach me via phone at
https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Wherem is the transmission
the back were the rear wheels are you need to check the fluid or just go ahead and chang hdrostatic fluid and filter best thing to do
