20 Most Recent
Balboa Instruments BALBOA 30 kW HEATER W PRESSURE SWITCH 15 INCH M1 M3 SYS TUV 50145 Questions & Answers
I need a users manual
First and foremost, there really is no such thing as a Value 3 System by Balboa. Balboa has a large line of systems with various names such as Value Pack Retrofit kits, VS, ES, GS, and our new LM8000 systems. If you can locate your product part number on your system, you can visit the Balboa Direct website manual downloaded section at:
BALBOA DIRECT MANUALS and download the latest manual for your product.
Hope that helps.
3/4/2012 3:47:43 AM •
Balboa...
Answered
on Mar 04, 2012
My balboa spa says sl
SLP or SL Message
If
the SLP or SL Message is Alternating with the Water Temperature on the
Display, the Spa is Operating in the Sleep Heating Mode.
If the
SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is
Operating in the Sleep Heating Mode, but there is No current water
temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
10/25/2011 11:20:57 PM •
Balboa...
Answered
on Oct 25, 2011
I have a balboa board
As
with any troubleshooting over the Internet, this is like giving a
haircut over the phone. So, that being said, this problem could be any
number of reasons.Here are some things you should have a spa technician look at (not in any specific order):
- Power connections
- Relay
- Whether the transformer is seated properly
- Whether there are loose wires
Disconnected
all the components and see if it still does the same thing. If not,
then one by one, reconnect the components until you isolate the problem.
If the problem persists, then you might have a larger problem like a
blown circuit board, etc.Hope that helps!
9/9/2011 10:55:14 PM •
Balboa...
Answered
on Sep 09, 2011
Im getting a f6 code on my digital control topside
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
3/18/2011 4:48:28 PM •
Balboa...
Answered
on Mar 18, 2011
My spa isnt getting power
Hi, if your Spa does not run, no power, nothing works, the you have to check the components associated with it which includes the Fuse, GFCI, Input wiring and High-limit switch.....
The 4 listed guide will help troubleshoot the malfunction using a logical progression of tests and observations, to isolate and identify the problem.
Electrical repairs can be dangerous, especially around water. I strongly recommend that repairs be referred to a qualified electrician or spa technician.
1/21/2011 11:12:11 PM •
Balboa...
Answered
on Jan 21, 2011
