20 Most Recent Black & Decker Black Decker RC3406 6Cup Rice Cooker Questions & Answers
I am trying to upload
A manual for the Rival RC61-CNcooker which is identical and made by Black and Decker is at:http://www.rivalproducts.com/manuals/MANUALS/RC61_43_53194273.PDF
9/11/2011 10:31:55 PM • Black & Decker... • Answered on Sep 11, 2011
0answers
Do you use hot or
I have used both hot or cold water....but have found that hot water works best to rinse the starch off and also makes the cooking process go faster...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
2/23/2011 4:19:11 PM • Black & Decker... • Answered on Feb 23, 2011
Lost the rice measurer, how much is 1 rice measure
About 2/3....
heatman101
2/18/2011 10:30:35 PM • Black & Decker... • Answered on Feb 18, 2011
Lost rice measuring cup I am not sure how much
Here is a tip that I wrote that will help you with using your rice cooker to steam your veggies...
How to Steam Vegetables in your Rice Cooker
heatman101
1/29/2011 9:35:08 PM • Black & Decker... • Answered on Jan 29, 2011
How many cups of rice do you put in when your
hi,
Tips on cooking rice:
You estimate first how many rice you are cooking then follows how many water you will be needing to cook it.
In an average, 1 cup of rice per person (depending on the persons appetite) = 2 cups of water. Rinse first the rice about 2 - 3 times to remove unwanted stuffs then start pouring and measuring the water.
Note:
1 cup rice = 2 cups water (common ratio), but there are also type of rice that requires more water or less water. You can adjust next time the water depending on the result. If the rice is a little bit hard then add more water the next time you cook. If the result is too soft then minus the water.
Hope you can cook now a perfect rice! Bon appetite!
Don't forget to rate me and thank you for using FixYa!
regards,
John
1/20/2011 1:11:14 AM • Black & Decker... • Answered on Jan 20, 2011
RICE COOKER DIDNT COME WITH
Not sure about your model but most work the same way. Measure a small cup of rice for each person and add the same amount of water. Water should cover the rice by about three quarters of an inch. Close lid turn on and let it do it's work. When it has finished, leave it alone for about 20 minutes for the rice to steam. It will stay hot, don't worry. Then fluff up rice and serve.
12/21/2010 8:18:50 PM • Black & Decker... • Answered on Dec 21, 2010
The swith is not working and no light is coming in
first try to remove the pot, then push the button in middle of the ricecooker..if th cooker light turn on then the problem is the spring..try to open your rice cooker, you will see the spring inside, try to stretch the spring
9/1/2010 1:58:06 AM • Black & Decker... • Answered on Sep 01, 2010
B&D CTO9000 Handle Replacement
Hi, it might be best to ask for a replacement compatibility appointment from Black & Decker by calling 1 (800) 544-6986. That way they can send someone out to your hour to check where you've attempting to install the handle. Or you might be able to email them the photos for the replacement area for faster results. Thank you.
10/19/2022 8:30:49 PM • Black & Decker... • Answered on Oct 19, 2022
Black&Decker B2300 Breadmaker - Metal on metal sound while kneading
Either the inner pan is not seated deep enough, or the bushing where the paddle comes through the pan has raised up a bit. Support - Parts for replacement parts on the Black and Decker website.
Deluxe Breadmaker - B2300 - BLACK+DECKER
www.blackanddecker.ca > products > kitchen > cooking
Enjoy the delicious taste of freshly baked breads with minimum effort. With 10 preprogrammed settings, you can easily prepare a nutritious loaf of bread or great ...
2/4/2021 10:17:19 PM • Black & Decker... • Answered on Feb 04, 2021
I have a Black & Decker bread machine B2300 which needs a paddle. Where can I purchase the replacement paddle?
Black & Decker is where I would look first followed by fleabay.
11/15/2020 9:29:19 AM • Black & Decker... • Answered on Nov 15, 2020
I have a Black & Decker digital steamer Model
I have the exact same problem - still no solution - this is the only posting I could find ... anywhere! If I figure out something, I will let you know. I love the steamer, but the beeping is also driving me nuts!
9/24/2019 12:41:02 PM • Black & Decker... • Answered on Sep 24, 2019
I have been gifted a Black & Decker Rice Cooker Plus RC866 but I need a manual in order to operate it.
Manualib.com has all the manuals that you can find and as long as your online 100% free. Just have your make and/or model number ready... you can find any manual even the ones that are hard to find. It also gives you the option to download, print, or even buy a copy of what ever your looking for... Hope this helped.....
7/18/2019 6:49:46 PM • Black & Decker... • Answered on Jul 18, 2019
I would like to know how to operate the black & decker air fryer given to me
black and decker site or online search --use model number
7/12/2019 12:08:55 AM • Black & Decker... • Answered on Jul 12, 2019
How to set black & decker horizontal bread maker for dough only
when the machine is plugged in, the settings should be indicated in a little window, Just keeping pressing settings until you see the word DOUGH or number 8 Press set, then start and away you go.
2/2/2019 8:34:04 PM • Black & Decker... • Answered on Feb 02, 2019
How do you reset Black & Decker bread maker cycle once started on wrong setting?
Remove cover and press the reset button.
11/4/2018 4:46:07 PM • Black & Decker... • Answered on Nov 04, 2018
Black & Decker Black Decker RC3406 6Cup Rice Cooker Logo
14 questions posted
Top Black & Decker Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Kitchen Appliances - Others
Most Popular Question
am trying upload
  • Kitchen Appliances - Others
