20 Most Recent
Philips HD4682 Cordless Electric Kettle Questions & Answers
Kettle Philips type hd 4686 leak
If the leak is under the kettle just replace it with a new one. Water and electricity are a DANGEROUS mixture. There is a VERY high risk of electrocution and of fire if you keep using this kettle. New ones are usually cheap enough for a basic kettle.
Philips air fryer fan not working?
There could be several reasons for fan not satrting.
1. Check the thermal fuse, if blown replace it
2. Check the timer which could need replacement
3. Finally, it could be the motor of fan itself.
How can i use my reward points earned in sbi
Hi, they explain it on their website: https://www.sbicard.com/creditcards/faces/pages/CreditCardRewards.jsp
Redeeming Power PointsWith the Shop & Smile Rewards programme every time you use your SBI Card you get Power Points. These Power Points can be redeemed for exciting rewards. Here is how you can get them:
Check your latest Card statement to see if you have accumulated a minimum of 1000 points.
Call the SBI Card helpline 39020202, if calling from BSNL/MTNL line dial 1860 180 1290 | 1800 180 1290 OR
write to us at PO Box 28, GPO, New Delhi- 110001
We will have your gifts delivered at your doorstep!
