20 Most Recent 2008 Toyota Yaris - Hatchback, 3-door - Base Rack System Questions & Answers
all pre gapped and probably iridium
2008 Toyota... | Answered on Jul 24, 2016
Undo the screws holding it in under the hood.
2008 Toyota... | Answered on Nov 17, 2015
do you have to add coolant and is there a rear heater core in rear ??
Thule Vehicle... | Answered on Feb 09, 2015
Are the bolts seized or is there a release pin?
Thule Vehicle... | Answered on Sep 02, 2014
Are these factory acessories or another name brand?
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
Thule Vehicle... | Answered on Jan 01, 2014
Demi,
The Loadcarrier 1061 is an older model and onl;ine data is hard to find, if there at all. To know more about the feet and fit kit, I recommend you call Thule Customer Support line at 800-238-2388 (Monday - Friday 8:30AM - 5:30PM EST).
Hope this helps. - RedRanger
Thule Vehicle... | Answered on Nov 16, 2013
Repost under RV for an answer
Thule Vehicle... | Answered on Jul 25, 2013
should be on the tail of tranny left side
Vehicle Parts &... | Answered Yesterday
You need to register with snooper to download the updates(even if previous owner has done so) or else you can ask him his user id and password
Vehicle Parts &... | Answered 3 days ago
You can use this for most of it. Most remote starts/keyless entry/alarm do the same things. Most are even colored the same way.
https://www.manualslib.com/manual/460639/Directed-Electronics-Autocommand-25523t.html
Vehicle Parts &... | Answered on Jul 11, 2019
Why you need a wrap? The new ones are wrapped mainly cos people don't like the company color and they want their ride to be unique. I believe it's the same for you. Vehicle wraps are better option; cheaper compared to repainting; easy to remove when you think you changing it.
Vehicle Parts &... | Answered on Jul 09, 2019
I would check your crankshaft sensor , also your fuel filter to make sure it is clear
Vehicle Parts &... | Answered on Jul 05, 2019
On most cars, you have to find any hidden screws in the armrests and remove those. Then if you have electric windows/door locks lift up around the base of them with a flat head screwdriver to get them to pop out and be able to unplug them. When that is done, you usually can just lift at the bottom of the door panel and you will unpop the plastic inserts as you work around the door.
What does this have to do with vehicle parts and accessories
I was asking myself this same question a couple of weeks ago when my friend mentioned his in conversation. I read a guide on Dig My Ride all about them, so I'll pass on what I learned.
Basically, radar detectors are passive pieces of equipment that can identify when a radar signal is being passed over your vehicle. In contrast to radar jammers, they can't disrupt or interact in any way with this signal, they just detect it.
People tend to use them as a kind of early warning system so that they get notified when the police are checking they're a vehicle with a radar gun to see if they're driving over the speed limit. Motorists who have radar detectors can determine when this is happening and reduce their speed limit accordingly.
Of course, it shouldn't really be necessary as you should always be driving within the speed limit regardless, but that's why people use them.
I hope this helps to answer your question!
2008 Toyota Yaris - Hatchback, 3-door - Base Rack System Logo
3 questions posted
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Marvin
Marvin
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Thule Vehicle Parts & Accessories
Most Popular Question
remove inner end tie rod end
  • Vehicle Parts & Accessories
