20 Most Recent
Bachmann 63598 Alaska Emd Gp40 Diesel Locomotive Questions & Answers
What kind of lubricant do I use for a Bachmann EMD
A light- plastic compatible oil for the wheel bearings, (a drop on a tooth pick)grease for the gears- a very small amount, a plastic compatible greaseDO NOT USE 3 in 1 oil or WD-40.lubrication kits are available at your local hobby shopor online train dealer...Labelle, Bachmann, Atlas all offer lube kits.
I bought bachmann spectrum 2-10-2
sounds like it's too lightweight! try running with a big blob of plasticine on top, to see of it runs right. if it then works ok you need to fill the internal spaces with lead (ask your local tyre shop for the weights they take off wheels when changing tyres)
Broken idler/reduction gear in ho power truck
Hi Jerry-
Split gears, unfortunately, often occur with plastic gears especially the older an engine gets it seems. They get brittle and crack.
I've provided a link to the Bachmann website-they offer a catalogue of parts and may have the replacement gear you require. You can also call them toll-free (the number is on the site) and provide the nice person with the model of your engine.
A little known fact is that Bachmann used to provide a lifetime guarantee on their locomotives. If the part you require is no longer made, they sometimes offer a replacement engine (new) at a substantial discount. You will have to mail in your old one. I used this service one time and received a brand new engine for about 60% off the cost of it new. A good deal!
My only other suggestion is to check in your area for local model train shows. You can search for them online. Most of the vendors are hobbyists themselves that sell model trains and supplies to make a few dollars on the weekend. Their trains are usually used but sell for a fraction of the price new. Sometimes you can purchase a beat up engine for its parts for a couple dollars, and sometimes they have parts that have been taken off used engines themselves. Bring your engine along with you and see what you can find. I find bringing an old engine back from the dead always very rewarding! Hope this helps! Happy modeling!
Bachmann Trains Online Home
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem.
To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue.
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life.
Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't
Crafting Clear and Effective Troubleshooting Guides: A Handy Guide for DIY...
Are you tired of scratching your head over malfunctioning gadgets or appliances? Fear not! With a well-crafted troubleshooting guide, you can conquer technical challenges like a pro. Here are some expert tips to help you write troubleshooting guides that shine:
- Know Your Audience: Understand who will be using your troubleshooting guide. Are they beginners, enthusiasts, or experts? Tailor your language and level of detail accordingly to ensure accessibility and effectiveness.
- Start with the Basics: Begin your guide with an overview of the problem and its potential causes. Break down complex issues into simple, easy-to-understand steps. Remember, clarity is key!
- Step-by-Step Solutions: Provide clear, concise instructions for each troubleshooting step. Use numbered lists or bullet points to outline the sequence of actions users should take. Include relevant images or diagrams to enhance understanding.
- Use Descriptive Language: Describe symptoms, error messages, and actions in detail. Avoid jargon or technical terms that might confuse readers. If necessary, define unfamiliar terms or provide a glossary for reference.
- Highlight Common Pitfalls: Anticipate common mistakes or misconceptions users might encounter. Address these pitfalls proactively to prevent frustration and ensure a smoother troubleshooting experience.
- Include Troubleshooting Tips: Offer troubleshooting tips or tricks to expedite problem-solving. Share insights or shortcuts that can help users navigate tricky situations with ease.
- Test and Revise: Put your troubleshooting guide to the test! Walk through the steps yourself to identify any ambiguities or gaps in instructions. Solicit feedback from users to refine and improve your guide over time.
- Update Regularly: Technology evolves rapidly, so it's essential to keep your troubleshooting guide up-to-date. Stay informed about new developments, software updates, or common issues reported by users. Update your guide accordingly to ensure its relevance and accuracy.
Remember, writing an effective troubleshooting guide is as much an art as it is a science. By following these tips and putting yourself in the shoes of your audience, you can create guides that empower users to tackle technical challenges with confidence. Happy troubleshooting!
I need 4 springs for under blades for a pro tech cs6007 contrator series planer
you can find replacement blades (also known as knives) made from a special V2 alloy (high-speed steel) on the MyWoodcutters website. Each set includes 3 HSS blades specifically designed for the CS 6007 model. The cost for a set of 3 blades is $61.50
to replace the springs for the under blades, I recommend checking with a local hardware store or contacting ProTech directly to inquire about availability..
For other parts or accessories, consider exploring online marketplaces like eBay.
