20 Most Recent Pentax MZ-60 QD 35mm SLR Camera Questions & Answers
2answers
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
6/15/2019 6:00:42 AM • Pentax MZ-60 QD... • Answered on Jun 15, 2019
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check: 1. You have left the lens cap on. 2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position. 3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is. 4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
11/19/2017 11:05:44 PM • Pentax MZ-60 QD... • Answered on Nov 19, 2017
Battery size
The MZ-60 takes a CR2 Lithium Photo Battery, available at most hardware stores, pharmacies and online at Amazon.com.
12/16/2014 4:00:59 PM • Pentax MZ-60 QD... • Answered on Dec 16, 2014
I cannot see through the view finder. When I take
Mirror lock up usually means that the batteries are dead. Replace the batteries.
2/16/2011 10:40:39 AM • Pentax MZ-60 QD... • Answered on Feb 16, 2011
Pentax MZ-60 SLR film camera,
Hi Joy. Do this. Turn it on and go into the menu. Locate the reset function. Reset the camera. All this means is that it will reset to factory settings, those that it was set to the day you took it out of the box. If that does not solve your problem, recharge the battery and try it again. If these steps fail, send it to pentax for a repair as there is nothing else that you can do that will not void the warranty. J.
7/9/2010 2:06:10 AM • Pentax MZ-60 QD... • Answered on Jul 09, 2010
How to go on manual
Having received no response in over a month, I assume this is no longer a problem.
6/8/2010 6:46:35 PM • Pentax MZ-60 QD... • Answered on Jun 08, 2010
My pentax mz60 will not take a picture? ive tried
go and serivce the camera
4/7/2010 11:54:53 PM • Pentax MZ-60 QD... • Answered on Apr 07, 2010
Can you get a digi body camera that will take the
You can try buying a Pentax SLR. But you most probably will need a converter to attach the lens.(That is if the lens will even work at all on the new body).
Cheers
Please rate!
9/28/2009 12:52:51 PM • Pentax MZ-60 QD... • Answered on Sep 28, 2009
Av flashing on the LCD.
hi i will give u the possible solutions. try out these solutions and one among these will work for u
1)you need to go into the menu , select settings and change av appurature setting to 2 instead of 1
2)with the lens compatibility / connection, U can fiddle around with the lens and try to find whether the aperture ring on the lens had moved from the 'A' (auto) setting to the one manual settings and when u switch it back to the 'A' setting it will solve the problem!
3) The lens is not completely set on the mount, maybe a little extra push in the turn may lock it in position properly
4)The contacts are dirty on either the camera mount or lens and it's blocking communication between them (but they hae to be very dirty though)
5)Highly unlikely, but you may have forced the lens into the mount the incorrect way (need to match the red dots). If that's the case you may have damaged both camera and lens.
but try out the solution no.2 that i have provided u... it will fix ur problem perfect
6/20/2009 3:55:13 AM • Pentax MZ-60 QD... • Answered on Jun 20, 2009
Pentax MZ-60 very ******* batteries
steve_macint,
the camera has a short circuit. if the camera got wet or was in very high humidity the flex circuit is shorting . take or send your MZ60 to a camera repair shop for an estimate. if the camera has liquid damage they most likely will not repair it.
however if it's just a component part it's fixable.
the battery drain will worsen as the short increases.
1/14/2009 11:36:01 PM • Pentax MZ-60 QD... • Answered on Jan 14, 2009
Trouble with Pentax MZ 60 camera.
does the camera work without lens mounted?
turn auto focus switch to manual focus when using non- auto focus lenses.
12/28/2008 3:05:44 AM • Pentax MZ-60 QD... • Answered on Dec 28, 2008
I cannot load the film
rootseya,
pentax error codes are in the repair manual for camera repair technicians. the camera needs repaired.take or send your camera to a camera repair shop for an estimate.
12/15/2008 10:28:07 PM • Pentax MZ-60 QD... • Answered on Dec 15, 2008
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
12/15/2008 6:12:23 PM • Pentax MZ-60 QD... • Answered on Dec 15, 2008
Pentax MZ-60 2x teleconverter lense
aturnbull1,
any good camera store or repair shop should have a 2X tele converter for MZ-60, new or used. i would try e-bay also.
12/10/2008 10:00:52 AM • Pentax MZ-60 QD... • Answered on Dec 10, 2008
Can you help me purchase a tele converter lens for a MZ-60 camera
You need to track down a 2x teleconverter that has a Pentax A mount for it to work correctly on the moun t of your camera.
I believe Adorama has one here:
http://www.adorama.com/PRO2XPX.html
Check with them first to ensure compatibility
12/10/2008 3:44:27 AM • Pentax MZ-60 QD... • Answered on Dec 10, 2008
4answers
Pentax MZ-60
have you tried cleaning the lens contacts with soft cloth?
ifnot do that.
is there no problem with out the lens in there?
10/11/2008 7:14:22 PM • Pentax MZ-60 QD... • Answered on Oct 11, 2008
Pentax MZ-60
please do a firmware upgrade
tell us what happened
10/8/2008 4:56:58 AM • Pentax MZ-60 QD... • Answered on Oct 08, 2008
0answers
Fog on right side of photos
Assuming the film door opens from the right, then the most likely reason is the light seal on the door. If it's just got dirty, brush it clean with a stiff brush. If it's badly worn then a camera repair shop may replace it for a reasonable fee - although I have done DIY repairs on this sort of thing using velvet :). Not for the faint-hearted tho'.
BTW the reason it's random is probably that it depends on how long each shot was in the gate before winding on and the ambient light conditions.
1/14/2008 3:50:45 PM • Pentax MZ-60 QD... • Answered on Jan 14, 2008
Pentax MZ-60 QD 35mm SLR Camera Logo
20 questions posted
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
View Most Popular
Pentax Photography
  • Pentax Photography
Most Popular Question
get digi body camera will
  • Photography
