20 Most Recent
Samsung B5310 Cell Phone Questions & Answers
Insert sim
Your SIM may be dirty. Clean the side with a connectors with a clean soft tissue paper. If this does not work then the SIM may be bad.
Insert sim
What is your problem with your Sim card? Is your phone shows the "No
Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is
so i am here to help you. If your Samsung shows the "No Sim" or
"Insert Sim" error then remove your Sim from your mobile and place it
again correctly. If your mobile shows the error
message "Invalid Sim" or "Sim Rejected" the your phone is locked to a
particular network. To fix this problem you need to unlock it. Use
unlock code to unlock your Samsung B5310. To get the code you have to
submit network provider, country and IMEI number of the mobile. Make
sure yourself whether you have knew the network provider to which your
mobile is locked, country to which the locked network belongs to and
IMEI number of your mobile. If not you can find the IMEI number in two
ways:1)Go to Options>status2)Find IMEI on the back of your mobile, behind the battery.3)Type *#06# and press call button. It will display your IMEI number.You
can find the network provider to which your mobile is currently locked
by switch off your mobile and switch on it again. A logo of the locked
network will get displayed on your mobile screen. After knew all these
get the code from the site
Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
I hav forgot samsung corby pro messages password, how to reset that without loosing messages???
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
I lost my PUK codes.
If you are in a situation needing your puk code, then you have to contact your mobile service operators. If your line is presently blocked, preventing you from making calls, then use someone else'e line, of the same network as yours to call your mobile service operators. Tell them you lost your PUK codes and they would provide it for you. Please dont ever make the mistake of guessing the code to use on your phone. It could lead to a permanent blockage of your line.Hope that helped you?Have a lovely day.
The keypad of my samsung
I was also wandering and searching for the same, but after much research I found out that it was due to the lock key, so just press your mobile's lock key 20-30 times, the problem will be resolved.... don't forget to say thanks....checkmytrade.blogspot.in
Unfreeze
Get the unfreeze code for your samsung B5310 model mobile from this
Mobile-unlocker.com , here it gives the easy methods to get the mobile unlocked........
