20 Most Recent
Magnavox ZV450MW8 DVD Recorder VCR Questions & Answers
When I insert a vhs tape into the turned on Magnavox zv450mw8 recorder it then shuts off, what goes
There are many delicate nylon parts in VCR's, they are usually the first to break, that is one possibility. The covers come off these pretty easily but I would pick it up and shake it first to see if something is rattling around inside, if you can hear something moving around in there and if it isn't something a child pushed inside (this often happens) then it is probably toast as it is more expensive to have fixed than it is worth. One other thing that is possible is that there is buildup on the capstan or tape guide rollers which can be sticky and wrap the tape around themselves and the machine will kick the tape out. If you are at all handy you could take the cover off, (FIRST MAKING SURE IT IS UNPLUGGED), plug it back in and insert a tape. As you watch the tape you can see at which stage of the cycle the tape backs out and maybe see the problem. As you can see many problems are possible, best to get another machine.
6/5/2014 6:08:01 AM •
Magnavox...
Answered
on Jun 05, 2014
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
5/16/2014 4:19:44 AM •
Magnavox...
Answered
on May 16, 2014
I need an operators manual
You can download and print the free instruction manual in PDF format by clicking this
link.
Please note: Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using
FixYa.
11/13/2013 12:58:50 AM •
Magnavox...
Answered
on Nov 13, 2013
Magnavox ZV450MW8 will not turn on
if no power indicator check for broken power cord, if ok at this time you will need to remove the cover of the dvd player to access the power supply.then look for blown fuse or any burnt parts here.
9/22/2012 11:30:23 PM •
Magnavox...
Answered
on Sep 22, 2012
Vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.Its called eating tapes.With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
5/27/2012 4:05:40 PM •
Magnavox...
Answered
on May 27, 2012
