20 Most Recent LG 52LD550 52Inch 1080p 120Hz LCD HDTV Black 52 in TV Questions & Answers
LG TV 52LD550-UB BAD HDMI INPUTS
Verify the link below for compatibility. Price listed is $135 LG Main Board REPAIR SERVICE 46LD550 52LD550 60LD550 Others EBU60852913
6/21/2017 8:16:29 PM • LG 52LD550... • Answered on Jun 21, 2017
My lg 52ld 550ub, has a problem . No picture, on lg logo comes on and red blinking light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/19/2016 3:10:29 AM • LG 52LD550... • Answered on May 19, 2016
My rca jacks only the yellow for video dosent work
You have to check the RCA cable that use. Try with another one. Also check whether the Cable box's video output is working properly or not. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
5/11/2016 3:30:21 PM • LG 52LD550... • Answered on May 11, 2016
0answers
Hdmi ports
Be the first to answer 4/19/2014 3:32:38 AM • LG 52LD550... • Posted on Apr 19, 2014Be the first to answer
0answers
0answers
52ld550-ub
Be the first to answer 10/1/2013 3:16:32 AM • LG 52LD550... • Posted on Oct 01, 2013Be the first to answer
0answers
2answers
I have an lg 52LG70,
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
11/4/2011 9:09:10 PM • LG 52LD550... • Answered on Nov 04, 2011
I have a LG dvd player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning. Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem. Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates. Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV. The hum is simply the player trying to read the disc. It can't so, it spits it out. Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
4/19/2024 8:46:44 PM • LG Televison &... • Answered on Apr 19, 2024
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG BD590 250 GB HD Network Blu-ray Disc Player. How to make LG BD590 region free?
Question edited for a lot more clarity. All in the link https://www.google.com/search?q=LG+BD590+make+region+free ..
3/17/2024 3:28:16 AM • LG Televison &... • Answered on Mar 17, 2024
How can I program my LG DVD remote control COV33662806 to my LG 55 Roku television.
You can't, the LG DVD Remote is single frequency. If you are lucky, the LG Television Remote, might control an LG DVD. If you have lost a remote, have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/15/2024 11:09:16 PM • LG Televison &... • Answered on Mar 15, 2024
Could you help diagnose the issue with my LG TV MODEL 65UN7300AUD that does not power on?
If you would like to share any clues, yes. Checked power going in, I presume. Any indicator lights? If yes, how many times does it flash?
3/15/2024 7:15:50 AM • LG Televison &... • Answered on Mar 15, 2024
2answers
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
faulty dvd reading lens,should be change by expert professional
3/14/2024 12:44:09 AM • LG Televison &... • Answered on Mar 14, 2024
LG 52LD550 52Inch 1080p 120Hz LCD HDTV Black 52 in TV Logo
14 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
lg tv 52ld550 ub bad hdmi inputs
  • Televison & Video
