20 Most Recent
Samsung UN32C6500 32 in HDTVReady LCD TV Questions & Answers
Comcast tv codes, samsung
Hello, Its quit simple to code search using the comcast controller.Hold the setup button untill it flashesPress 9 9 1 ...wait a second...press 1again.Next hit channel up on the remote untill the tv turns off and this may take some time. When the tv turns off press setup to save the settings and try to power the tv on with the comcast remote. If you find that the controller will work the volume and turn the tv off but will not turn the tv on you are on a slightly wrong code and you may need to code search again.
12/24/2014 1:27:05 AM •
Samsung...
Answered
on Dec 24, 2014
Hello! I have a samsung un32c6500 LED tv with a
Do you have sound? If you have sound and if the TV is responding to commands then I would say the main is fine. However if you don't have sound or video I would start with the power supply voltages. If you have sound and no video, I would suspect t-con but be advised, some manufacturers are building the t-cons into the panels !!!
11/3/2013 1:59:50 AM •
Samsung...
Answered
on Nov 03, 2013
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM •
Samsung UN...
Answered
on Oct 27, 2017
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
