20 Most Recent
LG 42LD520 42 in. HD-Ready LCD TV Questions & Answers
LG TV 42LD520-UA has no sound but the picture is great.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
When I plug the power cable only red light comes on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
When I plug the power cable only a solid red light comes out.
If it was on the street it is fairly safe to say it was not working. It is also fairly safe to assume that the previous owner did not think it was worth repairing. So why do you think it is a minor problem. You have the choice of spending some money to get a repair quote or dumping it. There is no way anyone can give you advice on fixing it without looking at it. Sorry.
Lg 42ld520 red light comes on and blinks a few
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sound goes up and down
Sounds like a dry joint or a capacitor has broken down, you will need to take back off and check, just remember there is 240volts in the PSU of the system.
Black line lg tv
You have a bad panel. Will be cheaper to buy a new TV than to replace panel.
42LD520 sound shorts out
if it has a headphone jack it could cause this--the jack when inserted cuts off the speakers to engage a headphone--try inserting a jack when it does this and wiggle it a little--jack socket has leaf contacts that can be out of positionIf tapping it could also be a bad solder connection somewhere.
Picture to big for screen
check the screen aspect. The picture has different setting that you can use. You might have your tv on a strech screen.
I have a LG model
Eack brand of the remote uses its has its own codes. What is the make and model of this universal remote that you have?
Please repost the question again with more details so we can help.
