20 Most Recent
Samsung PS50C451B2D 50 in. Plasma TV Questions & Answers
Live streaming
You should be able to do so with an HDMI cable
9/1/2015 3:06:27 PM •
Samsung...
Answered
on Sep 01, 2015
Why does my tv have sound but black screen?
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
6/28/2014 6:13:24 PM •
Samsung...
Answered
on Jun 28, 2014
I have a Samsung PS50C451B2D that has not turned back on since the extension cord it was connected to started to have a
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
5/31/2012 9:09:27 PM •
Samsung...
Answered
on May 31, 2012
Iv a ps50c45ob1w with no volume. what might be the problem
before you consider it needing repair check a few things:In menu of SET are SPEAKERS SWITCHED ON OR OFF?Is volume on SET or a Box if used down or muted.Does the set have an internal or external speaker switch?last but not least does the set have sound when a DVD etc is connected via the rear audio and video jacks?
4/28/2012 1:46:06 PM •
Samsung...
Answered
on Apr 28, 2012
Samsung PS50C451B2D screen broken.
Forget it---The cost of a PDP (plasma display panel) easily will exceed the cost of the set when new---not to mention major labor to replace it.
3/23/2012 10:11:40 AM •
Samsung...
Answered
on Mar 23, 2012
PS50C450B1W got crack in screen now tv will not
This may help to explain your problem.
http://news.softpedia.com/newsImage/How-Does-Plasma-TV-Work-2.jpg/
Underneath the glass there is a thin film of metal that is half of the "connection" that gives you a picture. When you cracked the glass that connection may have been severed and in doing so killed the tv. Sorry about the news :(
9/12/2011 2:23:21 PM •
Samsung...
Answered
on Sep 12, 2011
My New Samsung 50" Plasma (PS50C451B2D) keeps
if
timer is not activated, your unit needs servicing.
have the power
supply check first for output voltages it may not have enough to power
up some of the circuits board.
2/8/2011 9:58:56 AM •
Samsung...
Answered
on Feb 08, 2011
Hi i am trying to
Component video input is a high quality analog video signal separated by the three prime colors, red green and blue. You will need component video cables to make this connection.
Turn the television off.
Plug the connectors of each coaxial cable into their corresponding terminals on the TV.
Plug the other end of the cable into your other device that is also using component video, such as a cable box, video game console or DVD player, etc.
Power on the TV.
Press "component" on the remote.
Power on the device.
11/7/2010 8:01:40 AM •
Samsung...
Answered
on Nov 07, 2010
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
