20 Most Recent
Pentax Optio 33WR Digital Camera Questions & Answers
Images speed & capacity
You can read all about continuous shooting in the manual, here:
http://www.fixya.com/BrowseManual.aspx?mnlid=2575&prdid=153915&__PAGED_=58
Optio 33WR Sluggish Buttons
I had the 33WR last year, and opened it up. My subjective opinion is that it cannot withstand the pressure underwater. Someone tried it and water got in.
Optio 33WR SD Card Capacity
Don't own the camera - but the figures indicate the 512 should hold a max of 250. Please have a look at the following:
http://www.imaging-resource.com/PRODS/O33WR/33WRDATA.HTM
Will 5 year old cameras take a 16gb card
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
What battery do I use in the Pentax Optico WGII
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
Camera saying connection fail when trying to transfer photos to pc via usb cable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
