20 Most Recent
Microsoft KIN One Cell Phone Questions & Answers
When i flip up the phone, the lighting goes dim
have you changed the battery management settings I used to have a phone like this and the battery manage. was changed to power saver if so change it back to default it isn't anything to sweat about
Message connection problem on phone setup
Hi Melissa. This happened to me many times and well, I realized that my inbox was too full so I deleted all of my messages and tried texting someone who will usually answer back right away and that should fix the problem hopefully
Keyboard not working
Contact Microsoft for repair or replacement if under warranty. Otherwise it may be more cost effective to replace the phone.
Black screen
Probably a Bad screen or an error on the motherboard. Bring it to a local Phone store and ask, or search YouTube for a guide on how to replace parts of your cellphone!
My kin phone says it has no service
Good Morning:First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
Bought KIN one mobile from America.
Not
There Kin One is a CDMA phone which means you need a CDMA network. Australia used to have one (Telstra) but they closed down their CDMA network. You won't be able to use the Kin One in Australia I'm afraid!
KIN one phone back button will not work
when you hit the back button and the picture button at the same time it takes a screen shot. mine was randomly taking pictures in my pocket, it was so frustrating that i eventually just opened the back up and pulled off the shiny picture button :) my problem is when i close the keyboard the back light comes on but when i open the phone it turns off. HELP!!
My kin onem is stuck on symbol mode and wont let me type letters and i press the green button but it wont swich over
mY Dear:First:restore your Phone SettingsIF Restart problem not Solved So Secend Option:Please Format Your Phonewe can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.*#7370# or *#7780#Default security code is 12345release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card.If Problem Not Solved SoVery Best Solution:flash new software install in the phone problem will solved quickly
