20 Most Recent
Weedeater Gas Powered Hedgetrimmer Ght225le Questions & Answers
How to test a coil
Best way to test is with a 3-point spark tester. It will show if you have spark and if you have enough spark. Most dealers will have.
Hedge trimmer does not stay on
Will it start & run OK, does it stop after it gets hot then will restart & run again when it cools untill it warms up then stops again,it yes it can be a bad coil,I had this problem on a leaf blower.sometimes just testing for spark won't help you out it may still have spark but the electronics inside the coil that controls spark timing goes bad you could still have spark but it's out of time so the engine still won't run if you suspect this problem change the coil,bad coils can also make them hard to start.good luck
I have a weedeater model Featherlite 711334 and
There are two lines from the tank to the carburator. One picks up gas and fills the prime bulb, the other is a return line. The pickup line should have a filter on the end of it that is in the tank. The other line just dumps back in the tank. Usually the reason these lines deteriorate is because of ethanol in the gas. Make sure you're using ethanol free gas.
Black& Decker grasshog electric weedeater GH600.. 2007.Need advise removing the guard. No screw, but 3 springy tabs. I don't have 3 hands to move them at the same time
Removing the guard on your Black & Decker Grasshog electric weedeater GH600 can be tricky without three hands, but here's a method you can try:
1. Use a flathead screwdriver or a similar tool to depress one of the springy tabs while holding it down.
2. While holding the first tab down, use a second tool (another flathead screwdriver, a pair of pliers, etc.) to depress a second tab.
3. Once you have two tabs depressed, you should be able to use your free hand to push or pull the guard away from the trimmer.
4. If needed, use the same method to depress the third tab and completely remove the guard.
Alternatively, you might ask someone to assist you by holding down the tabs while you remove the guard. If you're still having trouble, refer to the user manual or contact Black & Decker customer support for further assistance.
My Hart 40V Electric weedeater won't start up with either charged battery
The first thing to check is the connections between the battery and your weedeater. Make sure that all connections are secure and there isn't any corrosion or dirt build up on the contacts. Additionally, you may want to try cleaning out the spark plug and checking for obstructions in the fuel tank or line. If these checks don't lead to a resolution, it may be worth contacting a service tech to further diagnose the issue.
Why is spark plug smell like it is burning
There can be a few reasons.
1. The seal on the spark plug is not sealing properly and the oil from the two stroke oil is leaking out and burning. If it is leaking from the centre of the plug, the ceramic core is broken. They are cheap enough to buy and easy to repair.
2. The cylinder head gasket is leaking a bit and burning oil off.
Make sure any filters on the fan(?) or the air filter are clean as it sounds like it might be overheating as well.
full make and model in all questions please.
