20 Most Recent
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Questions & Answers
Mitsubishi VS-4571 stopped working
The cost to repair will be about the same as a new flat 42"-47" screen LED. In addition due to the fact this is really obsolete tech you likely will not find parts.
Good afternoon, my Mitsubishi model
Error 2-3 means deflection loss
TV detects deflection circuit is not working thus show 2-3 error code
Possible causes are loss of main power supply that goes to deflection circuit and/or horizontal output transistor got shorted out and causing shut down.
Let me know if you are handy person and can test parts in circuit board of tv to provide you more technical info about problem or local tv repair shop will help you to fix it.
Thanks.
When I push the power button on the TV or on the
Sounds like a failed or at least failing power supply / power board
inside the TV.
Unfortunately this is a very difficult repair, and unless you are an
electrician I would not recommend attempting it. You will want to contact a local TV repair person in your area if you are sure this is out of warranty, more on that in a bit here. This is actually the
most common problem with this type of TV, I see it every day, it just
happens - sometimes with new TVs and sometimes it takes many years for
it to happen.
If you think it may
still be under warranty please contact the manufacturer to file an
RMA. If you happened to purchase the TV with a major credit card (not
a debit card) there is a good chance it may still be under the free
extended warranty most credit cards place on electronics. Please
contact your credit card company to inquire if they do this, and they
will be able to file the claim and get you a refund for the TV.
If
you want to attempt the repair yourself please let me know and I will
get you the part number and a place you can purchase it from for what
you need.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Picture shadow
Tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
2,2 means one of the pico fuses (see attached photo) that protects the convergence circuit is blown---This set uses 2 of the STK-394-250 convergence chips---you need to locate and replace the fuse and the chips---do not just replace fuse---it went for a reason, if just fuse replaced it will blow again and likely do other damage.
If this or the photo helped, rate this solution as very helpful as I do this here for free.
SD TECH
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Vs 4571
you must replaces many electricaly capacitors located on video board
good luck!!
Exact same problem red,blue,green lines and white bars at top
Your TV needs the convergence amp IC's replaced. The parts are about $60 for the Sanyo Type. They will last longer. Your previous TV Tech is most likely replacing these IC's and charging you for a new board.
Check with your local BBB to find an honest TV Tech. This job should not cost much over $325.
Power on
From what you have said it seems like the thermal fuse of the set is down... You will have to replace it and then check if it works..Post back if you need more help..
Good Luck!
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
