20 Most Recent
Mitsubishi VS-8087 80" Rear Projection Television Questions & Answers
My tv comes on, I
It does in fact sound like a lamp issue with the TV, unless you are an electrician I would not recommend that you attempt the repair yourself. The good news is that it should be repairable though, but you will need to contact a local TV repair person to do it. If you think you are capable of replacing it yourself you can get the part from www.partstore.com, but again I wouldn't recommend it unless you've done this before.
Thanks
Tim
After tv being on for
Hi todd
I`m going to help you with your tv but first;
Could i have your tv`s brand name and model number?
Looks like a plasma gone bad
if this is a VS-8087 it does not have a plasma. it has CRT's filled with glycol though. have a technician look at it. i have parts for this unit.
HD or not HD?
I don't think this is HD. i will let you know when mine comes in.
Mistubishi 6043 A
Is there anyway you can post a picture of the lines on your screen?
Mitsubishi VS-8087
There are L and R audio outputs in the rear, so you can hook it up to a surround sound system; no optical outs.
The screen size is 80 inches - but I'm sure your friend told you that.
Mitsubishi VS-8087
Convergence is usual cause of this problem.
Try performing convergence adjustment with
remote.
