20 Most Recent Mitsubishi VS-60603 60" Rear Projection Television Questions & Answers
Control board broke
Make and model?
11/29/2017 5:26:07 PM • Mitsubishi... • Answered on Nov 29, 2017
Need remote control
go on to ebay you may get one there
4/7/2014 11:21:56 PM • Mitsubishi... • Answered on Apr 07, 2014
0answers
Won't power on
Be the first to answer 3/13/2014 2:38:18 AM • Mitsubishi... • Posted on Mar 13, 2014Be the first to answer
0answers
Lock code
Be the first to answer 5/7/2013 3:44:11 AM • Mitsubishi... • Posted on May 07, 2013Be the first to answer
Goes off after power on
This set may have the self check, if power light comes on and goes off press and hold both menu and input on front of set for five seconds and let both go.power light will blink a two digit error code, like one blink, two blinks with a pause and repeat it for about five times total.Let me know what if any code is found, the 1,2 is NO error is found.
12/23/2012 2:09:08 PM • Mitsubishi... • Answered on Dec 23, 2012
Mitsubishi projection tv VS
do you have a sound?or its a dead set?
post back
7/27/2011 12:25:11 PM • Mitsubishi... • Answered on Jul 27, 2011
3answers
this was the perfect solution..my whole family thanks you for this information. It worked in two seconds!!
5/23/2011 4:49:50 PM • Mitsubishi... • Answered on May 23, 2011
2answers
Loss of picture
Fixed this problem today.. Go to Menu > Setup > AV Connections (Select Home Theater) > "Locked to Input 1", select "No" or "Off". Voila!
5/23/2011 4:47:27 PM • Mitsubishi... • Answered on May 23, 2011
We lost power to the
IF SET will not go to inputs (they do not show) this model (circa 1998) does have a OPTION menu to do a hard reset with the Mitsubishi remote.
I have the information. Confirm model and I will tell you how to attempt this.
If this told you something you did not know, rate this solution and comment here and I will tell you how.
SD TECH
5/23/2011 4:45:24 PM • Mitsubishi... • Answered on May 23, 2011
2answers
Cannot receive inputs other than Ant A and B
If ANyone need a solution for this stby
5/23/2011 4:42:11 PM • Mitsubishi... • Answered on May 23, 2011
Hi Recently I had Direct Tv come out and add a dvr
So the power button on the TV itself, and the remote power button do not work? Neither one will get the TV to power on and stay on? If so that is a very bad sign for the TV and is unrelated to the directv...
Let me know if that's the case and I'll tell you what's going on here.
Thanks Tim
10/3/2010 8:04:39 PM • Mitsubishi... • Answered on Oct 03, 2010
After a quick power outage, we lost everything,
On my Dir.TV box is a door in the lower right front. Behind this door is a red button. Press it and turn the box back on if it doesn't come back on by itself. It will go through a reboot cycle of 5 to 10 minutes. That should get the satellite going but I'm not sure about the TV input problem. Do you have a menu button on the TV? If so you should be able to find a way to change the input. If not, find your model number, then Google "TV remote" and you should find sites that will sell you an original remote. They will have a box that you can enter your model # into and tell you your remote number. Then Google that part number and shop for the best price. Good luck.
9/1/2010 3:12:44 AM • Mitsubishi... • Answered on Sep 01, 2010
My tv turns on then off right away its a
it is good if you have the service manual as your guide but if you have the courage to open it .....check the power supply section..
8/25/2010 10:33:48 AM • Mitsubishi... • Answered on Aug 25, 2010
When i press the power button my mitsubishi
Its ounds like the main transformer has gone bad or the power relay circuit. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
8/8/2010 3:32:39 PM • Mitsubishi... • Answered on Aug 08, 2010
When everything is plugged in
Hello Ryan. You have a loose connection within that tv. Your best bet may be to haul it into the local tv repair shop where they have the diagnostic tools and knowhow to find the short and repair it. J.
6/12/2010 10:09:45 PM • Mitsubishi... • Answered on Jun 12, 2010
Televison & Video Logo
86 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
lost power
  • Televison & Video
