20 Most Recent
Mitsubishi VS-50611 50" Rear Projection Television Questions & Answers
Lost remote, blue screen
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Tuner A/B Out
I think you may be missing a power supply voltage from the sweep supply from a shorted convergence IC or a Bad capacitor. Not alot a user can do as it is a splid state set and requires know how of the circuits to find out whats bad in that circuit. Please seek out a trained tech to assit you in this repair.
The picture scrolls vertically then may stabilize for a minute
Are you using the same S-Video in for the DVD player that you are using for the Cable Box? I would think probably not, but need to ask before going further. Are you unplugging the S-Video, plugging in the cable box, it has issues, unplugging again, then plugging in the DVD and it's fine in the same port?
Thanks
Tim
My Mitsubishi vs-5061 isn't working properly. The
Hi, this will occur when the convergence unit has failed . you will need to replace the convergence board in this unit in order to restore proper convergence functions. This is just below the optical assembly in the PCB main area next to the signal board and terminal block.
Mitsubishi 50 in tv model # VS-5061
First of all check the circuit boards to see if ant CRT coolant has bee leaking on them. A strong flashlight will work best to spot it. It will usually appear on the front half of the boards nearest to the screen,. Mitsubishi has had some issue with CRT leakage. Also check for solder cracks around the Convergence amp ICs. Let me know what you discover, or if you need anything more.
Rolling screen
Do self test first then get error codes, to do this look in threads here or ctechnicians.com
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
12/30/2007 10:31:10 PM •
Mitsubishi...
Answered
on Dec 30, 2007
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
