20 Most Recent
Sunbeam SB1800 Compact Sewing Machine - - Questions & Answers
Can not get thread through the hole in needle holder
Trying to thread the needle holder? You should be threading the upper thread through the needle's eye. If it won't fit, then the thread is too large for the size needle you are using. There are many needle types and sizes, so using the correct needle for the fabric and thread is important.
All About Needles
Doesnt stitch
Do you chose the right spool and put it the right side up?
I have a Viking Topaz 50 the touch screen is totally un responsive. Will an update reset it? or is it just bad?
Even if the touchscreen is unresponsive, you can still update the firmware using the spcialized software of the manufacturer. If it was unresponsive AFTER that, you would have to take it to a repair center. If you have difficulty with the general instructions which follow, try Viking customer support.
Here are the general steps to update the firmware:
Check for Updates: Visit the Viking website or refer to your machine's user manual to find the latest firmware version available for your model.
Download the Firmware: Download the firmware update file to your computer.
Connect Your Machine: Connect your Viking Topaz 50 to your computer using a USB cable.
Run the Update Software: Install and run the firmware update software on your computer. Follow the instructions provided by the software to update the machine's firmware.
Wait for Completion: The update process may take a few minutes. Ensure that your machine remains connected during the entire process.
Restart the Machine: After the update is complete, restart your sewing machine to apply the changes.
