20 Most Recent
Mitsubishi VS-45603 45" Rear Projection Television Questions & Answers
No picture only sound
This old tv likely has lots of capacitor problems by now !! JUNK it and save yourself as SERIOUS headache !!
My TV cuts on, then right back off
This is a very common problem among Toshiba & Mitsubishi RP TV's. It is caused by the circuit boards not communication with each other. The fix is about $600-700 with labor, parts, etc. I would suggest getting an LCD or LED TV.
My tv is locked and i do not know the code
Devices: Mitsubishi VS-45603 45 in. Rear Projection TV (only)I'm hoping your have a working original remote for this creature from 1998 (the dark ages of Analog).The first thing to try to reset a stored "lock code" is to unplug the set and leave it unplugged until the code is lost (or reset to the default). How long will this be? Mitsubishi won't tell (see below).-----------------------------------------------------------------------------------------------Service Codes are for the use of qualified service technicians only. Damage resulting from the unauthorized use of Service Codes will not be covered under warranty.Manufacturer: MitsubishiModel: VS-45603TV type: Analog Rear Projection TelevisionChassis: VZ5Year of Manufacture: 1998Option Menu Code: 1370Circuit Adjust Code: 2357Convergence Adjust Code: 2359<4><5><6>Since Mitsubishi fails to provide online support for its own products (even Users Manuals are unavailable), its left to the consumer to discover how to use & maintain Mitsubishi Electronics Products. Accordingly, I've no way to provide guidance on how to use the above Service Codes, nor is assistance possible if something goes horribly awry during the course of experimenting with them.Please post your results.
Mitsubishi vs-45603
This set is not HD capable.
When all signals are supposed to go to High Def., there is supposed to be a box that will convert the signal from 1080i to 480i.
I'm not sure how it will look, but, the down converted signal seems to look good for now.
The new technology is coming down in price and the new features are coming at us at record speed.
For instance:
The new tuners are capable of receiving local high definition stations using rabbit ears.
You don't need a cable box to receive all stations (except premium stations such as HBO) including High Definition if the turner has a "Clear QAM" tuner.
LEDs being used in LCD and DLP make them less vulnerable to loss of lamps prematurely and a heartier set.
LCDs and DLPs are becoming the set of choice due to contrast ratios as high as 100,000 to one and unlimited color.
A new type of set is just around the corner using laser technology (from what I have been told by manugactures).
In conclusion:
Your set is not HD, but, it should still operate when or if the change does take place. You may need to get more equipment to help with this change and it may cost more than buying a new set.
After big storm the tv
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
Program timer
you need the manual of user and read step by step, and you solution your problem....
Screen fades occasionally. Perfetc and them fades
Make sure that in the settings that your TV isn't setup to auto dim. I remember I had a similar problem. I think when ever a light would turn on or someone would walk near the TV it would get dim. It was really annoying. Check your settings. Good luck
