20 Most Recent Mitsubishi VS-50111 50" Rear Projection Television Questions & Answers
It could be a simple loose or broken wire,so
take back off and check it.Make sure unplugged first.
Could also be plug end.I have this with our Samsung,
but push the remote two to three times and it stays on.
LUCK
Mitsubishi... | Answered on Sep 25, 2014
Usually in these sets the 2-2 error code is a shorted convergence IC----they are protected in most models (don't know your exact model number) by two pico fuses(they do not look like glass fuses and are usually in the power supply--little green parts that look like small resistor--amperage is marked on them and usually they are 5 amp) the fuses can be checked like any other type of fuse---if one or both of these are open the set will detect no voltage to the convergence chips and shut the set down. If you locate the convergence chips look for any discolored or burnt resistors around them----in most models they are light blue in color and marked 3.9 ohms---if any are white in the middle they are gone---
I do this here for free so if this helps you give me a vote here.
if you need direct help: etower.766@netzero.net
Mitsubishi... | Answered on Mar 25, 2014
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Mitsubishi... | Answered on Dec 10, 2012
does any blinking light at the front then how many times does it blink? can you please give that info.
Mitsubishi... | Answered on Oct 16, 2012
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
Mitsubishi... | Answered on Oct 01, 2012
model indicated does not have a lamp or a orange light..............
Mitsubishi... | Answered on Mar 25, 2012
Mitsubishi VS-50111 50" Rear Projection Television Logo
86 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi vs 50111 tv not stay turn tv
  • Televison & Video
