20 Most Recent
Mitsubishi WS-55411 55" Rear Projection Television Questions & Answers
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
How do you adjust color
NORMAL adjustments are made with the remote in the menu--if color looks skewed or even 3d go into menu and select convergence--with remote see if will adjust.A better explanation of what the issue is might help and confirm model number if possible
Red diaiginal shadows
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
It is fuzzy when it
Cleaning won't help unless you have reason to believe it's unbelievably filthy inside, which is generally not the case. Plus cleaning the screen and/or lenses may make things worse if you aren't experienced. Many sets have a "magic" or auto focus procedure they can run on themselves to calibrate themselves periodically. Check your Owner's manual if possible, or look for a button that says something like "focus". This process takes several minutes, do not interupt it once started... good luck.
I have a Mitsubishi 55"
The part number is usually labeled on the board itself or there is a small sticker on the board that has the part number. If you can get me all the numbers that you see on the board I can tell you which one is the part number. Having said that it is extremely difficult to find replacement boards for old tvs like this one, but we can try.
Sai.
I have had this TV 6 months. Got it from a friend.
I don't want to seem condescending in anyway but i would try checking all your cables to see if they are plugged in properly and if that doesn't help id suggest buying new cables and testing those to see if your old ones have died out. If it isn't the cables then return them but at the least we've figured out what it isn't. Other then that i cant really see of any problem other then an internal one.
Ws-55411 getting a code 22
Check the pico fuses on the board. If one or more tests open, then likely the STK chips need to be replaced. This would mean a convergence failure.
Need to replace red lamp in my ws-55411 mitsubishi
In order to access the lamp, your going to need to remove the front bezzel, screen, and then access the display unit to discover the lamp. The process is not completely easy and I would only use recommended tools when taking things apart to ensure that you do not accidently damage anything. The reason why you can not see the lamp again, is because it is behind the screen and not behind the panel on the rear end of the tv unit. Hope this helps you out..
Bruce
No red
More then likely the red gun (bulb) had burnt out. It will need to be
replaced. Unfortunately its not an easy process and should be done buy an certified technician. Contact your local TV repair shop for a quote.
Thanks
Dustin
About 4 inches on both sides of screen looks
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Turn on the power and the green LED blinks on the
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER
LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv
for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the
fuses that protect the Convergence IC or IC’s is blown---set will detect no
voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO
GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
