20 Most Recent Mitsubishi WS-65313 65" Rear Projection HDTV Questions & Answers
0answers
I have small hoizontal lines running through my WS-65313 The only thing not grounded was mt outlet after a cold rain The screen will adjust for it convergance works .it's like I'm missing my
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
8/14/2017 12:06:03 PM • Mitsubishi... • Answered on Aug 14, 2017
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
6/7/2014 5:44:09 PM • Mitsubishi... • Answered on Jun 07, 2014
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
6/5/2014 7:19:35 PM • Mitsubishi... • Answered on Jun 05, 2014
2answers
My TV won't power on. Green light comes on, then off/ Error code 21
error code 2 1 is from the x ray protect or high voltage circuit. there are many individual components that can fail and cause that shutdown. to repair you would need to be experienced at troubleshooting electronics and would probably also need a schematic diagram. or have a shop repair for you.
6/5/2014 7:03:55 PM • Mitsubishi... • Answered on Jun 05, 2014
Hello, My name is Gennefer. My boyfriend bought me a lovely Mitsubishi WS-55313 65" Rear Projection TV from a yardsale that just so happened to NOT HAVE THE ORIGINAL REMOTE, AND IT JUST SO
Someone setup the parental restrictions. The remote you can look up and most likely order off of Amazon using the brand and model number... You'd have to somehow convince Mitsubishi to give you a "universal code" or other override or much easier, usually, get the code from the people that you bought it from...
2/23/2014 8:42:27 PM • Mitsubishi... • Answered on Feb 23, 2014
0answers
WS-65313
Be the first to answer 1/26/2014 3:45:39 AM • Mitsubishi... • Posted on Jan 26, 2014Be the first to answer
0answers
Cant get mitsubishi ws-63313 to go into hd
Call Dish back. Your HD signal has to be configured in your dish receiver. They can configure it for you over the phone. If not, then the dish guy has to adjust the wires at the splice box wherever it's located in your house. HD requires a dual cable line from the dish to the splice block. It's not the TV.
2/25/2013 7:49:59 AM • Mitsubishi... • Answered on Feb 25, 2013
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.also, don't buy any TV or electronics on CL as people dump their problems on someone else..
9/2/2012 11:56:49 PM • Mitsubishi... • Answered on Sep 02, 2012
Mitsubishi ws-65313 always says tv will turn off in 2 minutes, how do you stop this
It may be the reason they got rid of it but the set should have a hidden menu called Option which will allow a hard reset of the entire set and should cure the quirk the set seems to have==going to need and have the Mitsubishi remote and a four digit number code to do it.
8/28/2012 12:43:19 PM • Mitsubishi... • Answered on Aug 28, 2012
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
95 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
get mitsubishi ws 63313 go into hd
  • Televison & Video
